New headunit/hvac set up!
Old Feb 19, 2011, 09:34 AM
kyoo's Avatar
Wasn't sure exactly where to put this:
Updated set up with factory style grain thanks to cjramos, perfect fit and finish!
YOU CAN GET THE SAME SETUP HERE:
http://www.prtc.net/~cjramos54/index.html for $155! way better than orbital!!!!
JDM Factory Bezel: http://www.japanparts.com/db/parts_d...UMBER=00022810
+ your own double din head unit!
New Setup 2018:
New headunit/hvac set up!-jvriwfl.jpg
New headunit/hvac set up!-vdzmcgd.jpg
New headunit/hvac set up!-ud70pwa.jpg
New headunit/hvac set up!-7qnzayl.jpg
Old Feb 19, 2011, 10:18 AM
EVO.C's Avatar
nice.... very clean
Old Feb 19, 2011, 11:24 AM
killerpenguin21's Avatar
is that custom made? or?
Old Feb 19, 2011, 12:01 PM
4G63kevin's Avatar
Nice setup.
Old Feb 19, 2011, 03:39 PM
_______'s Avatar
Did you do the parking bypass? Its fairly easy on the bt
Old Feb 19, 2011, 03:45 PM
TougeGod7's Avatar
the both fit pretty bad if u ask me. the best fitting ones i have seen are the custom made ones out there but u have to cuz some of the hvac to make it fit properly
Old Feb 19, 2011, 04:05 PM
MattC28's Avatar
Definitely makes the dashboard more appealing, but where did you put the 3 gauges that were there before, or did your car not come with the oil temp/batt voltage/boost gauges?
Old Feb 19, 2011, 04:08 PM
_______'s Avatar
They belong in the trash, lol
Old Feb 20, 2011, 02:41 PM
chaotichoax's Avatar
that hvac panel could use some TLC...looks a little rough
Old Feb 20, 2011, 02:51 PM
vietman's Avatar
Does anyone make a kit like that? I know orbital doesn't make that kit anymore
Old Feb 20, 2011, 04:59 PM
EricLee7481's Avatar
I think RS and MR came with the factory 3 gauge setup as standard, but the gauges are optional on the GSR and SE. My SE didn't have the gauges, then again, the previous owner also did the 2-din setup before I got it.
Nice setup to the OP, I love my 2-din setup as well.
Eric
Old Feb 25, 2011, 09:56 AM
kyoo's Avatar
Sorry for the delayed response -
Yes it's fairly custom - guy just using the factory hvac panel, cut out and put into a radio relocation kit and then fiberglassed over and over.
_______, yes I had the bypass done - you actually have to move a pin, otherwise Pioneers will recognize that you've been messing with the parking brake. Exact instruction for it here: http://www.youtube.com/watch?v=D3_GvJ7ACbk
Touge, the fit is 100% spot on, the hvac used the factory relocation kit. The double din panel is from Japan, what they used in their lancers over there, and also fits 100% perfectly. The previous set up with the Orbital was TERRIBLE though. There are no gaps etc on the new setup.
Matt, no 3 gauges, not MR and didn't opt for it if it was an option
Chaotic, the person who made it used a matte black finish - it does look pretty bad in the picture with the flash, but in person it looks very good/smooth/clean.
viet - it was a custom job, I'm sure you can ask many custom fabbers.
Eric - Thanks, it really is awesome. I think the double din set up is invaluable for the older gen cars, esp with the hvac and all. Definitely makes the car a way better daily driver, esp with bluetooth ipod etc on and on, and just having a touch screen in dash navi has been invaluable for me personally. And way better then those flip out touch screens
Old Feb 25, 2011, 12:12 PM
bruce988jl's Avatar
Slick setup! I wish I bought the right double din surround for my setup.. The one I ordered has the same grain finish as the rest of the dash...
Old Feb 25, 2011, 12:13 PM
Yup, I love it, makes it that much more enjoyable when I drive. However, the headunit I have is kinda buggy sometimes (the previous owner put it in), and the screen becomes unresponsive when in cold temperatures, and it's getting kinda annoying...
Eric
Old Feb 25, 2011, 12:36 PM
05VIII's Avatar
would you mind telling me how the 2din was mounted? i just installed the avh-p4300 and it isnt centered around the jdm 2din bezel. also, the bottom sticks out a little too much which wont let the black surround piece sit flush to fill in the gap. im using the stock radio brackets to mount mine. what was used for yours? pictures would be nice. pm me if you can
Quick Reply: New headunit/hvac set up!
