Tire / Wheel Fitment Questions
#2987
How about Volk ZE40 in 18x9 +25et? I'm thinking the fronts should be ok but the rear may need a roll, which I was hoping to avoid. I'd do +35et with ease but it doesn't have enough concave.
#2988
As you noted, front fitment is OK
Stock rear camber setting OK to run after fender modification
#2991
18x9.5 +34 with 255/35/18 need a roll?
I'm thinking about picking up a set of Rota DPT wheels with the following spec: 18x9.5 +34. The owner told me this setup will clear brembos and doesn't need a roll in the rear with 255/35/18. I'm lowered with a -2 camber set all around. Would this setup work without any fender roll?
#2993
#2996
Hi guys, I bought XXR 531 18x9.5 +20 .... I know ill need a 3mm spacer to clear the front calipers but still undecided if I use 235/40 or 255/35
front and rears rolled and rear is slightly pulled.... 1.5" drop
which would be the best way to go 235/40 or 255/35???
#2999
