front sway bar
Old Mar 23, 2012, 04:01 PM
catman78's Avatar
front sway bar
hi all
doing an engine build soon and was considering installing whiteline while it's easy to get to
curent suspension is:
Dunlop starspecs
bilstein with Robi springs
full energy suspension bushing kit
whiteline RCK
car is a DD with a few HDPE days thrown in
if I did the front SB I would also do the rear
Thanks
Old Mar 23, 2012, 09:49 PM
Dallas J's Avatar
And whats your question?
Old Mar 24, 2012, 12:25 AM
ch53avitech's Avatar
+1
I'm lost
Old Mar 24, 2012, 12:31 AM
Chaz17's Avatar
Originally Posted by catman78
hi all
Dunlop starspecs
whiteline RCK
Thanks
Old Mar 24, 2012, 03:00 AM
catman78's Avatar
Originally Posted by ch53avitech
+1
I'm lost
sorry guys, posting and ****-tailing.
For those who have an upgraded FWB, is it a worthwhile upgrade if I plan on tracking car a bit more?
I like my current setup, however I figured for $187 it might be worth doing
considering the labor will be cake while engine is out.
Old Mar 24, 2012, 04:18 AM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
Big fan.
Whiteline front bar and Progress/Perrin rear bar -- great setup and can be tuned for the track/surface.
Old Mar 24, 2012, 02:09 PM
honda-guy's Avatar
im regretting that i didn't install front sway when my engine was out. but i was running NASA TTA class at the time and i thought it would be more beneficial to use the +2 mod point else where. now that i'm setting the car up for TTS class, i have no restriction on mods. if you're thinking of doing it down the road, do it now while you have a chance.
Old Mar 24, 2012, 03:29 PM
catman78's Avatar
Ordered and on the way.
Thanks all for your comments...
Old Mar 25, 2012, 05:52 AM
mouseIX's Avatar
I just installed my front bar yesterday when I was doing my clutch. I'm excited to see what it does!!
Old Mar 26, 2012, 07:33 AM
JDavenport's Avatar
If you are going to do it, do it now, real PITA as a stand alone job.
I got the Whiteline unit. Little better turn-in response, some improvement in overall roll control, and combined with the upgraded rear diff I think it helps with rotating the car under throttle.
I have been through many steps along the way, and the FSB like almost every other suspension part I have changed/upgraded has offered improvement by degrees. The only thing that has caused a huge change in the car for one mod has been the rear diff upgrade. That was a game changer on corner apex-exit.
Old Mar 26, 2012, 07:39 AM
Smike's Avatar
Agree with Jim.
It's a modification of degrees and feel. Not massive night/day; however, very noticeable and as I mentioned - with a good rear bar you can tune for the track surface.
Old Mar 26, 2012, 07:44 AM
Dallas J's Avatar
Once you get into the range of high spring rates (12/16k), you may find a bigger rear bar just isnt needed at all. I have one sitting on my shelf cause after the heavy rates, proper camber, and rear diff mods, I just didnt need any more rear bias.
Big front bar is absolutely needed with stickier tires. With the front MacStrut suspension you need as much roll resistance as possible.
Old Mar 27, 2012, 05:15 PM
kekek's Avatar
I would opt for the robispec bar and get the cusco ladder mount for the lca. This gives tons of adjustment options for different surfaces & tire setups. You can go softer for wet/cold conditions or stiffer for high grip. Works very well imo.
mrfred
154
Sep 12, 2023 10:19 AM
SoloSpeed101
May 12, 2015 06:48 AM
OverBoostedEvo
Jul 1, 2012 09:41 PM
MR White
Aug 1, 2011 04:23 AM
keith.
10
Mar 18, 2011 04:40 PM
Quick Reply: front sway bar
