Front End Suspension Noise
I've had a front end suspension noise going on and just looking for areas to look at for this noise. 2005 Evo with only Tein lowering springs.
When I am driving at slow speeds between 10-30mph it is a clunking type noise. It also happens when I am turning at the slow speeds. Any help would be appreciated as I will be looking at the car tomorrow.
I am thinking possibly of Control arms/bushings, swaybar end links, struts/shocks and such. Thanks for the help guys.
I had a clunking repetitive noise coming from my control arms up front, ended up being my LCA bushings were worn out. I replaced them with Perrins units and the sound is mostly gone. The only think left for my to change out is the strut hats so I assume thats the rest of my noise. Maybe the cause of yours?
if you get a crow bar on the lca and pry off the bottom of the car you shouldnt be able to move the arm much, if you can the bushings are bad.
Maybe check the CV joint? Clunking during low speeds as u mentioned makes me think CV joints. Check the control arm bushings as well as mentioned above. Good luck and keep us posted
https://www.evolutionm.net/forums/ev...-noise-50.html
There's alot of what to inspect on the thread I copied and pasted.
Mr.Sparkle
757
Apr 18, 2017 08:04 PM
Strtracer522
Feb 5, 2017 11:42 AM
SoloSpeed101
May 12, 2015 06:48 AM
RallySport9
Nov 30, 2012 08:39 AM
badev0
Nov 8, 2012 12:48 PM
