Evo 5 vs Evo 8 Knuckle/spindle ?
Hey Evo M,
Anyone knows if the evo 5 and evo 8 front spindles are interchangeable? Planning to run the evo 8 spindles to fit the Wilwood big brake kit.
Any help would be appreciated
Cheers
Cheers
Nope.
Evo7+ uses different front wheel bearing assemblies so the drive shaft spline is different.
The steering arm joint is in a different place, evo7+ plug in from the bottom, evo5 front the top.
The lower shock mount is wider on evo8 knuckles and the bolt holes are M14 vs M12.
You could probably get it all working if you mix and match stuff but the geometry might be stuffed up.
But in saying all that, brake kits are all interchangeable from evo4-9.
I had evo8 brembos on my old evo4 and my evo6 runs alcons for an evo8.
ToddRhodes
Jun 27, 2012 05:30 PM
bodybuilding88
Feb 1, 2011 07:01 AM
streetracerkam
Mar 22, 2009 07:53 AM
