Help - Best wheel & tire size set up for circuit racing
Hi guys I'm looking for a wheel that's going to make my Evo grip and handle like it should.
I was thinking...
*18 inch Diameter (To clear huge racing calipers though I only have stock size Brembo's at the moment )
*9 or 9.5 inch width ( to run at least a 255 tire )
*38P (to retain stock steering and suspension geometry)
Iv spent the last couple hours looking online but most popular brands like (Ray volk / Enkei / Work emotion / Advan) do not offer 38P in these sizes
When I did find something it will not clear brembo's
Perhaps I need to consider 17x9 38P
Does anyone know of any wheels that would meet these criteria and could point me in the right directions
Im also happy to listen to suggestions and personal opinions on different sizes and offsets. but as far as im aware staying 38P would be the best for an evo.
Thanks in advance Kevin
I was thinking...
I was thinking...
I was thinking...
Cheers and good luck
And always have fun and be safe!
CB
The car isn't a circuit dedicated race car, Its just a street driven evo that will see the occasional play days (which is just entry level/practise track days) for fun.
Im just wanting something that is set up perfect so it can get on the track and mean business from the word go.
My car is currently on 18x10 25P Advan RS with stretched 225/40/18 tires.
Now that may look "cool" along with many "stance" or "hellaflush" set ups you see these days
But that was not what the Evo was made for.
I'm just looking to for a wheel/tire combo to grip and perform hence why im looking for something with a 38 offset. While allowing me to run some big tires like 255.
I run the same size Dunlop Star Specs on stock wheels on a dedicated track car. Buy a cheap set of stock wheels and have fun! I promise that you will not be able to squeeze all the capability out of the stock setup your first, second, or even 10th event. I'm just trying to save you money.
This!
+1 I ran a track event on stock wheels and 245 star specs. It was just fine for the novice group. I would reccomend a similar set up. Also make sure you get good brake pads and fluids before you track it. if not, youll spend the whole day cooling the brakes.
Gramlights makes the 57dr in 18x9.5 +38. The 18x9.5 +35 konig milligrams on my car work very well also. With a 265/35r18, you just need a goof fender roll with a bit of pull in the rear.
i did my first track day (in this car) with 18x9 Rota SVNs with Nitto 555r tires. that was my street setup that worked "okay" on the track. they were heavy and not too sticky. not too sticky was a good thing, though. i learned the car on that setup (not my first track vehicle, but much different dynamics than my FWD car).
i now run a 17x9.5 +38 RPF1 with a 255 "street" tire (Hankook R-S3). but i worked up to it.
as mentioned above, the BEST thing you can do is put a decent tire on the stock wheel. 18s are pointless because, really, you probably won't be needing a big brake kit any time soon and the 18s are needless weight. oh, and the tires cost quite a bit more.
now, if you are going with a BBK and 18s for looks? you may or may not see a performance gain but you are still adding needless weight to the car and adding it in the worst place. unless you are going with some really baller parts, you will end up with, essentially, a slower car. but! the car will look better and can still be a ton of fun and perform well enough.
it's up to you how serious you want to get.
FWIW, i see lots of podiums and records set with 255/40-17 tires.
this is very, very, very bad LOL. you won't be able to wipe the smile from your face once you get a nice set of wheels/tires on there!
18's offer the performance advantage of a shorter/stiffer sidewall, especially in 265 and 275 size tires. As well ad the ability to run a 285/30. The weight difference is negligible. Also, my wheels are still light. An 18x8.5 milligram is 18.9lbs. I'm sure the 9.5 is less than 2lbs heavier. A 20lb wheel is about the same weight as the stock Enkei wheel, I think they're around 20-21...
And 18's look better :P
thanks guys for the suggestions, right now im looking at Evo X wheels (non bbs) and using 255/35/18. Fitment sounds like no drama's and it actually looks really nice when painted Gunmetal or bronze.
