GTX3576 vs GTX3071 2011 MR
The 3576 was done on a new Dynojet. The 3071 was two years ago, on a Dyno Dynamics.
The tuner recommended a 3.5" Intake because I'm tapped out on the 3" one...
My mind is blown that you gave up almost nothing under 4k ! I would have thought going from a gt30 to gt35 turbine would have cost you more under 4k. Correct me if I am wrong but Garrett only makes a gt30 Evo x flange turbine housing; correct ? (And atp)
This is the #1 Stock location bolt on turbo you can buy, but it still has great spool and plenty of top end pull. I do a lot of HPDE instructing and needed a turbo with good mid corner modulation and response.
If your on a budget the Mitsu MHI is great but doesn't have the top end this unit has...
If you can spend the $ on a t3/t4 setup look at the Borg Warner setups..
Its the ATP Hot side setup:
http://www.boostresource.com/product...turbo-upgrade/
and this pipe:
http://www.boostresource.com/product...r-outlet-pipe/
counterforce661
Mar 4, 2016 09:55 AM
Anexos
Evo X Dyno Results
13
Jan 22, 2014 10:36 AM
c_reber
Oct 29, 2013 11:30 AM
