Strange Boost Curve
Old Mar 24, 2015, 08:11 PM
Brez!'s Avatar
Strange Boost Curve
See attached boost curve.
Car: 2010 SE
Cobb Stage 2 (panel filter and TBE)
3rd gear pull at WOT
Logged using AccessPort
1. No matter what we do to set the boost, it spikes (as high as 29psi) - it was set to 24 in the attached curve
2. Why does boost climb after I get off the throttle?
Thoughts?
Brez!
File Type: pdf
Old Apr 2, 2015, 01:15 AM
simonpvs's Avatar
Are you able to log your wgdc correction?
Either you wgdc is too high and/or your correction interval may not be often enough. Not having used an AP before, I'm not sure how you check/log that, but it would be the first place I checked.
Also, are you running the stock bov?
bobby.is.rad
Mar 21, 2012 12:21 PM
rartist
Jun 29, 2005 07:36 AM
bigjhoney
Mar 15, 2005 06:24 PM
EVO8LTW
Jan 25, 2005 01:57 PM
OX
12
May 8, 2003 11:29 AM
Quick Reply: Strange Boost Curve
