(Works) trans linkage shifter bushings
Old Jun 30, 2009, 05:35 PM
Mark B's Avatar
Question (Works) trans linkage shifter bushings
Has anyone installed these on the x and if so how well do they work in respect to the 2nd to 3rd problem .
Old Jun 30, 2009, 05:56 PM
Eurorcr's Avatar
I installed mine last Friday and I can't believe how much more precise/crisp the shifting is. They didn't look like much when I received them and I wondered if I just wasted my money but I am very pleased.
My 2nd to 3rd shift problem was cured by draining the factory tranny fluid and replacing it with Redline MT90. The tranny now shifts like butter!
Old Jun 30, 2009, 05:57 PM
Eurorcr's Avatar
I live in Michigan also if you'd like to take my car for a spin to check them out for yourself
Old Jun 30, 2009, 06:18 PM
Mark B's Avatar
Thanks guys, that is what I wanted to here , Where in Michigan & DID YOU JUST CHANGE THE TRANS FLUID IN THE GEAR BOX.
Old Jun 30, 2009, 07:15 PM
Clipse3GT's Avatar
x2
I have both sets. The shifter bushings and the transmission bushings from WORKS, along with AMSoil MTG. I barely have any issues at full temp with these. I only have a little bit of a difficult shifting from 1st to 2nd. But that goes away after 2-3 shifts.
It's a good idea to go with urethane since its more forgiving then bare metal which changes with temperatures, especially in the north.
Old Jul 1, 2009, 06:22 AM
Eurorcr's Avatar
Beverly Hills, a northern suburb of Detroit (Near Birmingham/Troy area). I only changed the transmission fluid. I did not change any other fluids such as the diff's, rear end, etc..
I also bought the works short shifter and counsel bushings and will be installing those two items over the next few weeks. Get your X on the track! I will be doing this event on July 25th:
http://www.3ballsracing.com/index.ph...ask=view&id=22
ODUB
Site Feedback / Suggestions
Mar 9, 2011 02:59 PM
jonhix09RA
Sep 13, 2010 09:54 PM
Quick Reply: (Works) trans linkage shifter bushings
