Radium fuel surge tank with OEM FPR and OEM fuel rail
Old Oct 18, 2015, 06:10 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Nothing to see here, this forum sucks.
Old Feb 2, 2016, 11:30 AM
RazorLab's Avatar
Bumping this because I have been getting some PM's lately asking why their fuel pressure is 90psi at idle after installing a radium surge tank with radiums wiring directions.
This solves that problem!
The key is the progressive fuel pump controller and wiring everything properly. W hich I outline in detail above, even with a nifty wiring diagram.
Old Mar 20, 2016, 03:32 PM
Chiroke666's Avatar
Old Apr 6, 2016, 03:38 PM
icemann's Avatar
Hey
Hey thanks for posting this I saw a video about this today and I'm about to buy a evolution x again and I remember with just getting the fuel pump relay I would still have fuel pressure issues even with the dw650 or whatever pump it was I forgot.. but I'm starting to get my build together to put down 550 on pump gas.. this doesn't seem that hard to put together maybe it is because I have an electronic back ground lol.. the issue I could see is the routing of the hoses maybe.. what about catch cans have you added those as well ?
Old Apr 6, 2016, 03:42 PM
RazorLab's Avatar
Catch cans for the engine? Nope.
Old Apr 7, 2016, 10:06 AM
icemann's Avatar
Do you understand and know what the use for the catch can is for?
Old Apr 7, 2016, 11:12 AM
hoobastnk90's Avatar
Im sure he does, but if you search a little you will find what there used for and how they work.
Old Apr 7, 2016, 11:29 AM
icemann's Avatar
Ohh I know what there used for and how they work man.. I was just curious about this because im getting my set up together first everything to do before getting into the engine becauses that's like 8k its self unless I want to do the work myself but then its going to take loner with work...
Old Dec 6, 2016, 05:53 PM
The_X_Effect's Avatar
This write is amazing razor! I have the same exact set up now after u recommend it to me for on the track. Only differences are my controller has the integrated map sensor. It is gonna b a pain installing unless I put the controller in the engine bay unless there a special hose that I can use that won't create a vacuum lag if I mount it in the trunk?
Old Dec 6, 2016, 08:45 PM
RazorLab's Avatar
Put behind your glove box or use hard plastic vac line to the trunk.
ossimbrian
Jan 24, 2019 04:27 PM
six40
Jan 31, 2018 11:37 AM
Evo_AK
Feb 2, 2016 09:26 PM
17579EVO9MR
May 15, 2011 06:53 PM
Quick Reply: Radium fuel surge tank with OEM FPR and OEM fuel rail
