Installation Guide - Evo X Retrofit CCFL Halo Projector Headlights
This is a step by step installation guide for 2008-2010 Mitsubishi Evo X *Retrofit* CCFL Halo Projector Headlights. You can get them from www.dashzracing.com and get the $100 discount at evolutionm.net's market place:
EvoX *Retrofit* Projector Headlights with Inner Halo & LED Strip
08-10 Mitsubishi EVO X CCFL Halo LED Projector Headlights - Black
Red Inner Halo:
Blue Inner Halo:
Yellow Inner Halo:
These projector headlights has 3 color for the inner halo which are red, blue and yellow, but the installation for all these 3 kind are the same, before the installation start, there're tools that are recommended to use to make the installation is smooth:
Tools Required:
- Handy Remover
- Trim Pad Remover
- Flat Tip Screwdriver
- Phillips Screwdriver
- 1/4" Drive Ratchet
- 1/4" Drive Extensions (6-10 in)
- 10mm Socket
To connect the halo and LED, you need following tools:
- 4 x quick connectors
- 4 x male crimp connectors
- 4 x female crimp connectors
- 2 x red wire, 2 x black wires
- wire striper
- wire crimper
- voltmeter
2. Remove 5 Clips above the radiator and take out the radiator shelf
3. Remove 12 clips and 6 bolts below the vehicle
4. Remove 3 clips and 1 Bolts behind the wheel for left and right wheel
5. Hidden behind the bumper where the emblem is located, there is a clip, a bolt and a harness. Pop out the clip, unplug the harness and take out the bolt.
6. Take out the 4 bolts as indicated by red arrows
7. Remove 2 Bolts right in front the lower bumper
8. Start Pulling from the side and take out the front bumper. Put the front bumper on a safe surface to prevent scratching the bumper
9. Unplug the harness from the light bulbs. Remove the bolts that holding the headlights and pull out the headlights.
10. These CCFL headlights require connecting the resistors, please connect the resistors as followed:
11. Put back the headlights to the location after wiring the halo and the LED. Put back the front bumper and plug in all harness. YOU ARE DONE!
Red Inner Halo:
Blue Inner Halo:
Yellow Inner Halo:
Tools Required:
- Handy Remover
- Trim Pad Remover
- 10mm Socket
- wire striper
- wire crimper
- voltmeter
could someone post a night pic of our X's day lights? haven't received mine yet so i'm curious to see how they look (in case i want to order sth like this), but i can't find any decent pics by googling
Hi Everyone,
Dashzracing is doing a New Year special to everyone, if you have a facebook account, you are quality to this Giveaway contest:
Just click the banner above and like Dashzracing page, then post a reply to this picture in Facebook, then you are enrolled in this DRL LED Fog Lights contest.
Remember, you have to:
1. "Like" Dashzracing's page
2. Post a comment on that giveaway DRL LED Fog Lights Banner in Facebook
Have fun and Good Luck everyone!~
