ASC and 4 wheel drive issues...
had sway bars and a meth kit installed in my 2010 X. The subframe was dropped to far and had to pull the steering coulmn the put it back in. Afterwards the ASC and 4 wheel drive system warning lights came on. The installer had no idea what happened and the dealership is saying that is a comms error and they can not read the computer.
Does anyone have any clue or ideas on what I can do to figure out why the systems are throwing these codes and causing the problem. The installer pretty much told me that his install could have not cause this issue, then though it happened right after his install.
Any and all help I will be greatful for.
I had an issue when they dropped the subframe, the steering wheel wasn't kept stationary. When they went to connect the column to the rack, the wheel has been spun and it broke two sensors in the steering wheel. Even after replacing them, the computer required resetting to clear all dash lights. Hope this helps.
Where the sensors in the wheel it self? Thus requiring a new wheel?
delkat
117
Jun 10, 2010 09:53 AM
2010, asc, chesapeake, drive, dynamat, evo, issues, lancer, light, mitsubishi, motorsports, problems, steering, va, wheel
