Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Sidewall Damaged - Advice?
Old Mar 15, 2010, 10:56 AM
b1g4l's Avatar
I replaced the stock Yokohama tires with 4 Dunlop Direzza Sport Z1 Star Spec's about 6,500 miles ago. Yesterday, I nailed the curb pretty good taking a chunk out of the front right tires sidewall, and doing some cosmetic damage to the wheel. I'm looking for options as I know it's important to keep all 4 tires wear relatively even and I don't want to risk driving on a damaged sidewall. From similar posts, it seems my options are to buy 1 tire, and have it shaved down or replace all 4. In addition to getting some advice, my question is if I buy 4 new tires (4 new Z1's), is it possible to re-integrate my current 3 tires back into the rotation cycle?
Is 6,500 miles enough wear to constitute buying 4 new tires?
Old Mar 15, 2010, 11:02 AM
Toxin's Avatar
Pics. Without that we can't tell you much. How much are the tires worn? Buy 1 and shave it a bit maybe?
Old Mar 15, 2010, 11:08 AM
goofygrin's Avatar
you've got the options nailed. If you buy 4 new ones (ouch) then you really shouldn't try and put them into the rotation... I'd say just sell them.
But I think they cheapest option is to buy one and have tire rack shave it for you to match the depth of the others.
Old Mar 15, 2010, 11:24 AM
b1g4l's Avatar
Here are pics:
Old Mar 15, 2010, 11:31 AM
b1g4l's Avatar
The tires are worn pretty much what you would expect from a DD Evo with no track time with a little spirited driving here and there. I got 23,000 miles out of the OEM Yokohama's if that gives you a good idea...
Old Mar 15, 2010, 12:08 PM
DirtyCookieX's Avatar
I feel your pain but I only had around 2000 miles on my tires.
https://www.evolutionm.net/forums/ev...-sidewall.html
To make a long story short I went to the goodyear shop I bought my tires at and he said they were ok, thank god. You should be ok
Old Mar 15, 2010, 12:24 PM
►EvolutionX◄'s Avatar
Based on looking at your tire. it looks as though the rip gets deeper and deeper as it goes on, I would not even consider driving at high speeds with that tire, If you just want to replace the one, the difference in the tires should be NO MORE than 2/32 of an inch, otherwise you could cause problems
Old Mar 15, 2010, 12:32 PM
personal_golf's Avatar
purely cosmetic...albeit bad cosmetics but you should be just fine...drive on sir. If you just want peace of mind...measure the other 3 and if they are with 2-3/32nds...just buy a new one. Good luck.
Old Mar 15, 2010, 12:35 PM
b1g4l's Avatar
Thanks for the advice thus far. I don't feel comfortable driving on the tire, and I definitely want to replace it just for the peace of mind. My plan of action as of now is to get the tread depth measured at a tire shop, and have Tire Rack shave down a new tire to match the existing 3. I'll let you guys know how it goes as I'm sure this situation comes up from time to time. It's so hard to buy a $200 tire and say "Yea, now I want you to take that brand new tire and add wear to it."
Old Mar 15, 2010, 04:49 PM
LaXGSR's Avatar
Good plan - better safe than sorry! That's a pretty significant chunk off the side, plus potential impact damage that you can't see. Good luck!
wompa164
Aug 30, 2015 10:13 AM
Noize
19
Nov 17, 2012 12:01 PM
_EVOlved_
19
Oct 5, 2011 12:03 PM
Kieffer87
23
Aug 26, 2010 08:01 PM
shadow1
Feb 22, 2010 06:36 PM
Quick Reply: Sidewall Damaged - Advice?
