Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Can't wait to put these on!
Old May 9, 2010, 01:01 PM
MiStEr GiZmO007's Avatar
Pro Racer GN+
18 X 9.5 Offset 38
Color: HMC (Hyper Metallic Chrome)
What you guys think?
Old May 9, 2010, 01:11 PM
hotdog's Avatar
Offset of of 38 is going to look weird, assuming it even clears the brakes.
After an ultra fast lol-google, according to Wheeldude, the Grids at +38 wouldn't fit the X:
The 18x9.5 +38 model will not fit the Evo X. The Rota Grid has a ton of concave and will require a lower offset to clear the front Brembo calipers. We make this model in 18x9.5 +20 fitment specifically for the Evo X
Now, these ain't Grids, but the same answer might apply.
Old May 9, 2010, 01:16 PM
monkey_187's Avatar
your best bet is to use spacers or send them back and get the right offset
Old May 9, 2010, 01:17 PM
Domolution's Avatar
Looks like you might need some spacers for those. I might be wrong though.
But other than that, they look real nice.
Old May 9, 2010, 02:31 PM
ugakirk's Avatar
Yeah offset is too high. Look and see if they have something closer to 20ish.
Old May 9, 2010, 06:16 PM
This is from the %zigen website... 18×9.5J ●12/ ●22/▼38/43
Do you think 22 offset will be good????
●Clears Silvia, Skyline, Fairlady Z, Supra big caliper
▲Clears Impreza OEM 4POT caliper
▲Clears Impreza Brembo caliper
■Clears Lancer Evolution Brembo caliper
▼Clears GTO fitment
Old May 9, 2010, 06:22 PM
jackygor's Avatar
you ll need a 20 mm spacer!
Old May 9, 2010, 06:26 PM
so 38 offset will not fit then ??? cuz they told me it will clear and will fit to my car ! dang now im thinking hard..... cuz i dont want them to ship it then i gotta bring it back !!!!
Old May 9, 2010, 06:44 PM
CatalystGod's Avatar
▼Clears GTO fitment
Its not the calliper you should be worried about in this case. With a higher positive offset, You are basically reducing the gap beween the strut and the wheel. So you might see issues on that front. For an 18X9.5, +20-28 offset is ideal. You can just get a 10-15mm spacer and call it a day. You should be fine. And not to mention, there's the whole sweep radius blah blah blah side to this whole wheel size argument, please don't make me explain. You'll find tonnes of info online about this.
Old May 9, 2010, 06:59 PM
I forgot to mention to you guys that 2008 My Evo X MR is not lowered or drop still stock .
So i want to know and make sure that DO YOU GUYS THINK THAT I WILL BE FINE WITH THIS SET UP 18X9.5 OFFSET 38 WITH BRIDGESTONE RE960 POLE POSITION 245/45/18???
PRO RACERS GN+
Old May 9, 2010, 07:29 PM
mlomker's Avatar
Did you get a killer deal on the +38's or what? You'll certainly improve your odds by going with a 245 tire but why buy wider wheels to run stock tire size? Among those options I would have done +22.
If you use a 10mm spacer then you could run 265's and you come out pretty much flush with the wheel well (I have +28).
Old May 9, 2010, 07:35 PM
lol!!! i did .. and my mechanic said that the tires that i have will strech and will fit fine.... So should i go 18x8.5??? come on guys help me out .... 18x8.5 and 18x9.5 is only a inch differents right ????
so i think i should be fine then .... right ???????
Old May 9, 2010, 07:37 PM
Methodical4u's Avatar
don't know anything about offsets... I like the wheels though.
Old May 9, 2010, 07:39 PM
mlomker's Avatar
It'll work. I'd run the spacer. You can always get wider tires next time.
