runing rich on idle
Are you running V7 tephra mods? If so knock down your timing idle correction to around 4~5 degrees this will help prevent hunting. Lower the base timing a few degrees in the idle load areas. If it idles to low you can increase your IAC counts in the look up table. Don't expect a steady 14.7 with those 2150's cause it ain't gonna happen.
If your really that worried about it you need to add this table to your rom and tune it to the 2150's. It's a PITA but once you get it dialed in it's sweet.
https://www.evolutionm.net/forums/ec...ion-table.html
ArchieBabes
Mar 12, 2007 08:31 PM
