08+lancer stereo wiring diagram
Old May 30, 2008, 06:28 PM
bigd31388's Avatar
guys need help
there was no dash kit for the 08 lancer about 6 months ago so i cut the factory connector so i could splice to get my aftermarket deck to work...
couldnt find the right cables so i custom grounded, +12v,constant and remote..
now i have the dash kit and i was wondering if any one new what wire went to what
for example
yellow green bdsafasdf = black?
someone please help
Old May 30, 2008, 08:59 PM
YeOldeLancer's Avatar
most of the time the wire colors are universal.
red = battery
yellow = ignition
orange = illumination
black = ground
green, purple, grey, white = speaker (-)
above with stripes = speaker (+) or vice versa
blue with stripe = remote wire for amp
Those are the essential wires for almost ANY head unit install.
I don't know if this is what you meant but hope this helps
Old May 30, 2008, 11:58 PM
bigd31388's Avatar
no that didnt help not even a little.. i install car stereos.. i need to know mits wiring diagram not the universal one we all know
Old May 31, 2008, 11:11 AM
well you didn't have to be a dick about it. try making your question a little clearer next time. and fiy, not everyone knows what all the colored wires mean.
Old May 31, 2008, 11:40 AM
bigd31388's Avatar
o im sorry bro. didnt mean to come off like an a$$. just tryed making things more clear. thank you for helping out tho appreciate it
Old May 31, 2008, 01:25 PM
jamesm80's Avatar
Hey,
Installed my Kenwood Head Unit/10 CD Changer system today and was unable to get a harness in the UK. I managed to get an 07 Lancer harness plug to connect to the car loom by modifying it somewhat. The speaker wire colours i found were as follows:
Front Left Speaker + White/Blue
Front Left Speaker - Black/Yellow
Front Right Speaker + White/Red
Front Right Speaker - Black/Red
Rear Left Speaker + Yellow/Blue
Rear Left Speaker - Gray/Blue
Rear Right Speaker + Yellow/Red
Rear Right Speaker - Gray/Red
From what i recall, Red/White was permenent live and Yellow/X was ignition live. Just check them with a meter to be sure.
The tweaters appear to be on seperate wires so they don't work for me at the moment. Need to take a better look, maybe have to install a crossover onto the front speakers.
Hope this helps.
James.
Old Jun 1, 2008, 07:15 AM
bigd31388's Avatar
i did it myself with a voltmeter
red is actually the constant which = yellow for aftermarket
yellow is the 12v ignition which = red for aftermarket
there are two blacks and only one of them are ground
so you will have to play with them to figure which one is actually ground..
now this is only for the guys that cut there factory radio wire harness off and are only playing with wires
Old Jun 1, 2008, 03:54 PM
hey it's cool. thanks for the info as well.
I'm trying to find wire diagrams for the amplifier wiring cuz I want to replace the factory amp and sub. I get what you're asking about now cuz I have no idea what each wire is! Why does factory have to be b!tches about wiring?? lol
If it were all aftermarket setup like the rest of the world it's be so much easier.
Old Jun 1, 2008, 07:32 PM
SmoothdrJay's Avatar
How about the wires colors for us with the Rockford Premium System?
I talked to metra today, and a harness is in development, but there is no eta for release.
Old Jun 1, 2008, 08:38 PM
yeah. that's what I'm asking about.
I'd go and experiment but I don't want to mess around with the harness.
Old Jun 1, 2008, 11:49 PM
Yeah, its really pissing me off... Ive got the metra dash kit, my DVD head unit installed and powered up w/my satellite hooked up. Just NO sound... Its a tease.
I have read the schematics in the factory service manual, and have found two remote turn on wires that go from my HU to the factory amp, but am lost after that. Normally i would run an RCA to the amp, but not sure when it comes to stock wires.
Old Jun 2, 2008, 03:00 AM
OMFG... After weeks of searching i believe i may have stumbled upon the answer to all my problems...
http://www.mediafire.com/?n1icjm3xndm
The wiring diagram for the 2008 Lancer w/Rockford Fosgate 9 speaker system... Im taking this info to my installer tomorrow, and ill post up to let you know how it goes.
Old Jun 2, 2008, 03:05 AM
FOSGATE PUNCH® 9-SPEAKER AUDIO SYSTEM
Fit Guidefe-
Radiofe-
Mountingfe-
DIN Fitbfge
DIN Fit Kitbfge
Openingsfe-
Radio Depth 7.75 (INCHES)
Standard Radio Opening CORPORATE PANEL
Radio Picture Click to view image
Optional Radio Opening 1 CORPORATE DOUBLE DIN
Audiofe-
Radio Informationfe-
Radio Optionsfe-
Radio Security YES
Speed Control Volume NO
Steering Controls YES
Satellite Radio OPTIONAL
OE Satellite Brand SIRIUS®
Batteryfe-
Wire Color RED/WHITE
Polarity (+)
Location RADIO HARNESS
Pin # 20 PIN PLUG PIN 10
Accessoryfe-
Wire Color YELLOW
Polarity (+)
Groundfe-
Wire Color BLACK
Polarity (-)
Pin # 20 PIN PLUG PIN 20
Dimmerfe-
Wire Color GREEN/WHITE
Polarity (+)
Pin # 20 PIN PLUG PIN 9
Power Antennafe-
Wire Color PINK
Polarity (+)
Pin # 20 PIN PLUG PIN 14
Amp Turn Onfe-
Note THIS VEHICLE USES CAN DATA SYSTEM TO TURN THE AMPLIFIER ON
Old Jun 2, 2008, 03:06 AM
Radio Outputfe-
Speaker 1fe-
Front Leftfe-
Wire (+)fe-
Wire Color WHITE
Pin # 28
Note THESE WIRES SUPPLY THE AUDIO SIGNAL TO THE AMPLIFIER
Wire (-)fe-
Wire Color BLACK
Pin # 38
Front Rightfe-
Wire (+)fe-
Wire Color RED
Pin # 26
Wire (-)fe-
Wire Color GREEN
Pin # 36
Steering Controlsfe-
Steering Controls 1fe-
Wire Color BLUE
Polarity (+)
Pin # 22
Note THIS WIRE SUPPLYS A REFERENCE VOLTAGE TO THE STEERING
CONTROLS
Steering Controls 2fe-
Wire Color BLACK
Polarity (+)
Pin # 32
Note THIS WIRE USES RESISTANCE ON THE REFERENCE WIRE TO CONTROL
RADIO FUNCTIONS
Vehiclefe-
Integrationfe-
Radiofe-
Electrical Constraints NONE
Physical Constraints NONE
Solution NONE
Productsfe-
Metra Electronics Corp.fe-
99-7011 MITSUBISHI LANCER 2008
Old Jun 3, 2008, 04:19 PM
so how did the install go?
there isn't info about the amp harness, which kinda sucks but it's good info none the less.
Quick Reply: 08+lancer stereo wiring diagram
