Lancer 1.3 GLX CK1A fuel gauge advice
Old May 27, 2016, 11:40 PM
fariom's Avatar
Hello everyone,
I have a Lancer 1.3 GLX (CK1A) 1.3L '99. I am facing a problem regarding the actual fuel in the tank and the fuel gauge. When I fill the tank, the needle goes slightly over the F line. However when the needle reaches the red E line I get no fuel warning light and the tank still has about 15-20 liters left. If I continue driving -ignoring the needle- I see the fuel warning light coming on (with about 8 liters in the tank). At that point the needle has dropped at the lowest possible point (far lower than E-at the bottom of the gauge). This makes me assume that the warning light works ok, but not the needle.
I took out the fuel gauge unit (located under the rear seat), measured the ohm resistance at F and at E according to the service manual and the readings were OK. I even tested the ohm resistance at various points (eg. at half tank, at 1/4 tank, etc). The fuel gauge unit reacted normally. I even tested the float heights and everything was normal.
Any advice as to what else might have problems?
Old May 31, 2016, 10:48 PM
fariom's Avatar
Update: I replaced the fuel gauge unit just in case. The results remain the same. I took out the combination meters and measured the ohm resistance of the fuel gauge instrument too. Seems normal accoring to the service manual.
The problem seems to be increased ohm resistance going to the fuel gauge instrument causing it to drop lower than what the fuel gauge unit is actually sending.
Could a worn wire travelling from the fuel gauge unit to the fuel gauge instrument increase the ohm resistance?
Old May 4, 2018, 09:46 PM
Jetblue15's Avatar
Guage
Check all wires going to the sender unit, make sure the insulator on the wires are intact and not damaged and grounding on the car body
Old Jan 5, 2019, 08:33 PM
brayan's Avatar
I got a similar problem, as someone in this thread said, replace the unit and in the pivot point of the unit add a little of general purpose oil like WD-40, sometimes if it is aftermarket or even oem it may be a little sticky, causing floater to keep up even when the tank is low, so at any time is fells and make a good reading, you can make it with the use one too, and see if it fix it.
zucariniwalter
04-06 Lancer / Ralliart Show / Shine
Oct 16, 2010 10:11 PM
Lancer7
Jul 23, 2006 08:55 PM
crazynasty
Dec 27, 2005 05:41 PM
tuxman
Jul 17, 2005 11:32 AM
lanevorockz
Lancer Troubleshooting
Apr 17, 2002 11:23 PM
Quick Reply: Lancer 1.3 GLX CK1A fuel gauge advice
