Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Official Wheel/Tire Info Thread
Old Apr 13, 2008, 06:01 PM
  #46
BaD2RaSS's Avatar
Originally Posted by Lancerlover
The GTR concavity face on Advan racing wheels have a minimum with of 8.5 inches. I dont think this will sit well with our cars. The offset and bolt pattern are perfect but I think the rim size will cause a rubbing issue. Anyone able to slap on an 8.5 inch wide wheel?
Anyone try this yet because im looking at getting these......
http://cgi.ebay.com/ebaymotors/18-In...spagenameZWD1V
But im still not to sure if that offset will work they are 18x8.5 at a 35 offset
Old Apr 25, 2008, 05:38 AM
  #47
JasoonDE's Avatar
I have a lancer DE, I was wondering if 18x7.5 215/45/18 tires would fit on my car. I assume there is not much different in gts to de?
Old Apr 25, 2008, 10:38 AM
  #48
Blacksheepdj's Avatar
They'll fit perfectly. Don't forget to make sure the offset matches, though.
Old May 3, 2008, 09:16 AM
  #49
AhFuJai's Avatar
ok im getting wheels soon... i want 18x8 +35 offset and im planning on using the stock size tire... will rubbing be an issue?? + i will eventually drop it around 1.5 inch all around... im trying to get the most agressive setting possible without rubbing issue...
Old May 4, 2008, 11:45 PM
  #50
LancerGT1987's Avatar
Wheels: 18" X 7.5" ASA AR1 Silver w/ Machined Lip Wheels
Offset: +48mm
Tires: 225/45/18 Bridgestone Potenza RE960AS Pole Position
H&R Sport Springs: 1.4" front drop, 1.3" back drop
Any idea if this will fit on there without any rubbing issues?
Thanks!
Old May 5, 2008, 05:08 PM
  #51
Should be OK. Not sure on the offset.
Offset: +48mm
Thanks!
Looks fine to me. Shouldn't be any problems.
Old May 5, 2008, 06:23 PM
  #52
Yaayy! But what if I decided to go with the RRM GRIP Springs V2? 1.5" front, 1.4" rear. Any problems there? Still kind of deciding between both sets of springs.
Old May 6, 2008, 09:06 AM
  #53
AhFuJai's Avatar
Originally Posted by LancerGTS
I have 18x8 wheels with 235/40R/18 wheels.
This is with the WORKs springs that have a 1.1 drop.
No rub issues even during autocross, turning hard and hitting the brakes.
assuming that his offset is +45 on those wheels...
if i got 18x8 +35 with stock size tire 215/40R/18 it should fit according to this site
http://www.bigcustomwheels.com/rt_specs.jsp
by the way thats a pretty good site... does most of the calculation for you and it also tells you about clearance and all
Old May 6, 2008, 09:09 AM
  #54
Haha I just posted that on LT.com last night! That site saved me from trying to figure out all this offset stuff which I just can't seem to understand...
EDIT: Maybe it was Project Lancer... either way I posted it on some Lancer site =P
Old May 6, 2008, 12:34 PM
  #55
stefan.bounket's Avatar
That is an amazing website
Old May 8, 2008, 03:49 PM
  #56
SHOULD still be OK, but I'm guessing. You'll be a lot closer, obviously, but I doubt you'll get rubbing unless it's an extreme pothole or something. You're staying pretty close to stock, so it shouldn't be a problem.
Old May 20, 2008, 12:31 PM
  #57
KaizLancer's Avatar
will 17" konig unknowns with 225/45/17 fit on an es?
Old May 20, 2008, 02:58 PM
  #58
LuDa's Avatar
i would think they would
but sheep do you think 18x8.5 would fit without rubbing? or is it sketchy?
Old May 20, 2008, 09:46 PM
  #59
LuDa - I have no clue. I've seen a few people ask about 18.5", but I don't know of anyone trying them.
225 should fit fine Kaiz.
Old May 21, 2008, 02:13 AM
  #60
LuDa's Avatar
would increasing them to 19s make any diff? as far as rubbing issues and such goes? or just the with is what matters..
ive seen 18x9 on a ES before..dont know how many problems they had
but i guess the only way to find out is to try them on i would guess..
Quick Reply: Official Wheel/Tire Info Thread
