Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Oz Rally Suspension and Ralliart Suspension?????
Old Sep 21, 2008, 02:12 AM
Lilevo808's Avatar
Hi, I have a Mitsubishi Lancer Oz Rally Edition 2004...
I was wondering if stock Ralliart Shock/springs/strut could fit on a Oz rally?????
Old Sep 21, 2008, 09:05 PM
senate6268's Avatar
Yes.
Old Sep 21, 2008, 10:14 PM
Lilevo808's Avatar
Originally Posted by senate6268
Yes.
Thanks a lot bro... Reason why is because my friends and I awhile back installed my tein drop springs... We got the back installed but couldn't install the front because my friend accidentally strip the main bolt to take off the spring... So we cut the front stock springs... So I'm running cut stock springs in the front and tein drop springs in the back...
I wanted to change my Lancer back to stock suspension for now till I can afford full suspension later...
Could I install my Tein drop springs for my Oz Rally into the Ralliart stock suspension?????
Old Sep 21, 2008, 10:18 PM
ambystom01's Avatar
Yes. Get rid of those cut springs, you're going to blow the struts like that.
Old Sep 21, 2008, 10:23 PM
Lilevo808's Avatar
Yeah I know bro... I went the cheap way... I was stupid before and wanted to drop my car the cheapest and fastest way... I guess I learned the hard way...
Old Oct 23, 2008, 08:08 AM
lancerguy0208's Avatar
So you can install just Ralliart springs into a OZ with an otherwise fully OEM setup?
Old Oct 23, 2008, 08:27 AM
ambystom01's Avatar
I would assume so.
Old Oct 23, 2008, 02:21 PM
I hope so...
Old Oct 23, 2008, 02:23 PM
lancer2show's Avatar
yup. im using coilovers made for the ralliart.
Old Nov 21, 2008, 05:39 AM
snakoil's Avatar
yes you can use ralliart springs on OZ...It will lower the car for about an inch
I do suggest you use the ralliart struts too as they are a bit stiffer and improve handling
Old Dec 2, 2008, 07:11 PM
Juan Martinez's Avatar
They do fit. I asked rrm I believe about putting them on an ES. They said I just had to swap out the top mount for the ES. After that, I could use OZ or Ralliart since they where both the same.
Old May 26, 2011, 03:55 AM
NatesEvoVIII's Avatar
can you use ralliart suspension on an evo? vice versa too?
Old May 26, 2011, 05:56 AM
turbotime's Avatar
nope.. will not fit.
Old Jun 1, 2011, 03:05 PM
jman85's Avatar
even if you switch out the top hat?
damianjclarke
15
Aug 24, 2015 08:21 AM
teammvm
Lancer How Tos / Installations
Oct 5, 2014 05:26 AM
malancr
Lancer Troubleshooting
Mar 13, 2012 08:48 AM
da2003pizimp
Mar 11, 2005 04:49 PM
Quick Reply: Oz Rally Suspension and Ralliart Suspension?????
