2002 lancer es o2 sensor Heater circuit malfunction bank one sensor one
Old Dec 1, 2012, 04:22 PM
Johnny402Ne's Avatar
Code p0135. The thing is looks as o2 was recently replaced. I believe they changed with Universal 02. Thing I'm having trouble is wires have been cut and switched around. Coming from the car is four wires one black one white coming out as one and seems there is a bear wire also coming out going to nothing. And two single wires along side black and the other blue. Now from the top o2 also has four wires. Blue,white and two black. Which ones should be together so this code can be gone and the car can run right. Also have three other codes p0421 Warm up catalyst efficiency below threshold bank 1. P0446 evap vent control solenoid circuit malfunction. P0302 Cylinder two misfire.
Old Dec 2, 2012, 07:45 AM
pin 1 - red/yellow +12V
pin 2 - black ground
pin 3 - blue/red heater ground
pin 4 - white signal
| 1 2 |
| 3 4 |
1 = BLACK ---> heater ground
2 = BLACK ---> heater +12V
3 = WHITE ---> ground
4 = BLUE -----> O2 signal
Old Dec 2, 2012, 07:50 AM
I did research and this is what I came up with. Could someone please tell me if this is correct? Thanks.
Dwilson36
May 5, 2016 11:05 AM
bigben
Sep 13, 2013 03:48 AM
MagicManRed
Oct 25, 2011 10:57 PM
cyrax5709
Lancer Engine Management / Tuning Forums
18
Aug 13, 2010 11:58 PM
RogueSTi
37
May 7, 2006 01:58 AM
Quick Reply: 2002 lancer es o2 sensor Heater circuit malfunction bank one sensor one
