2002 Lancer OZ Rally problems
Old Mar 7, 2017, 05:11 AM
Tyrese Smith's Avatar
I have an auto 2002 Lancer OZ that I just had a stereo installed in and when it was hooked up , my right tail light lost power, instrument cluster/ dash lights went out, HVAC and gear shift also do not light up anymore. I've replaced every fuse and traced every wire back with no luck. New alternator , new battery, still nothing. If anyone has any suggestions please help. My heater is also stuck working while driving even when it's in the OFF position. Also when the steering wheel is straight there's a sound almost like air deflating but when I turn the wheel even a 1/4 inch it goes away. When idling it shakes very hard and makes a rattling sound but as soon as I put my foot on the gas pedal it goes away. Even if i don't actually push down on the gas. A/C also doesn't work , it blows out hot air. I charged it up and it still didn't work. Somebody please help me.
Old May 24, 2017, 01:35 PM
Ajbran77's Avatar
Any luck on the solution? I have a 06 Rally w the same issue.
Old Jun 20, 2017, 10:20 PM
Moronicicon's Avatar
Stereo install and lighting issue, normally that is because you have the illumination wire hooked up and not the dimmer. Don't hook up the orange wire in the adapter harness for the stereo. If you unplug the stereo connector do all your lights work properly?
lancerguy0208
Lancer Tranny/Drivetrain Tech
Jan 14, 2017 12:56 AM
CJBarker2
Dec 22, 2016 07:24 PM
pgooch
Lancer Troubleshooting
Aug 15, 2015 07:48 PM
pgooch
Jun 29, 2015 07:06 PM
Chris D.
15
Apr 28, 2012 06:53 AM
Quick Reply: 2002 Lancer OZ Rally problems
