Mid-Atlantic Region Includes DC, DE, MD, VA, WV.
Crank Pos Sensor
Old Mar 8, 2016, 04:47 PM
Bhsj13's Avatar
Crank Pos Sensor
I have searched and have not found anything. if anyone could help with giving the the simple steps to replacing this sensor, it would be great! Thanks for the help in advance.
Old Mar 8, 2016, 06:50 PM
3gturbo's Avatar
You need to remove the serpintine belt, water pump pulley, crank pulley lower front case cover then you can get to it.
Old Mar 8, 2016, 07:29 PM
Bhsj13's Avatar
Cool, thanks for the tips. if it aint the cam pos sensor then it will be this next to do. btw, which one is more likely to start going bad first?
Old Mar 9, 2016, 11:09 AM
Ev0ikon's Avatar
For that sensor your need to follow the same steps as replacing the timing belt.
Old Mar 9, 2016, 05:51 PM
Bhsj13's Avatar
got it, thanks!
Old Mar 11, 2016, 12:38 PM
Bhsj13's Avatar
It turned out to be the Cam sensor, thanks for the help guys!
Old Mar 13, 2016, 07:41 PM
Bhsj13's Avatar
.... now my fuel pump is going out also LOL! will be fixed tomorrow.
Old Mar 26, 2016, 05:21 PM
Bhsj13's Avatar
MAP sensor losing signal and MAF is down LOL, hope to be running again soon.
Old Mar 26, 2016, 06:01 PM
roni4g63's Avatar
is your battery in a good state?
Old Mar 27, 2016, 08:39 AM
Bhsj13's Avatar
sure is,
heyythurr
Nov 3, 2014 11:52 AM
_des_
Mar 8, 2012 07:56 PM
BoostinBird
May 11, 2010 04:17 PM
hybrids14
Mar 19, 2007 01:06 PM
rt turbo
Oct 16, 2004 06:52 AM
Quick Reply: Crank Pos Sensor
