threw crank, and cam pos sensor codes: off timing? please read
Old Oct 15, 2004 | 04:36 PM
rt turbo's Avatar
threw crank, and cam poss sensor codes: off timing? please read
ok, i made a new thread cause the old one was dead. i threw 2 codes, po335 and po340. crank, and cam angle sensor codes. i just put the motor at top dead center (the cam gears lined up to marks) i looked down at crank pulley and found the mark up, so i know the motor is tdc.
THE QUESTION IS: the mark on the crank pulley was lined up between the 2nd and 3rd to the right (front of engine) marks on the block (i had a hell of a time seeing this, but managed). further description: the mark on the crank pulley lined up 3 marks to the front of the motor from the end of the marker on the motor(3 marks to the front from some writing on the engine marker that i couldnt read).
scetch description of crank pulley marker:
?writing?
I_________I________I_________I_______^___I________ _I (front of motor-->
each marker is the line i could make out from the marker on the motor from front<--to back--> the arrow (^) is where the crank pulley lined up when cam pullies were at tdc markers.
---- where should the crank pulley line up on the motor marker to be at TDC when the cam gears are at their TDC markers?
Old Oct 15, 2004 | 04:40 PM
evotoo's Avatar
check evomoto cam install guide. it has a pix of where the pully mark should be at when TDC.
Old Oct 15, 2004 | 05:21 PM
rt turbo's Avatar
well, looking on evo motos web site, wat i depected above seems to be correct. . so that means the car hasnt jumped timing. im still stumbling during wot after 5500 rpms. and i still have those 2 codes. i dunno where to go now. any ideas?
Old Oct 16, 2004 | 06:52 AM
LateSleeper's Avatar
I got those exact codes once when I stalled my car after having a new clutch put in. When it stalled, I got a SEL light. I pulled the codes and cleared them. They haven't come back in 5000 miles. Do you think your codes could be false?
marinejensen
16
Jul 7, 2015 07:18 AM
heel2toe
46
Mar 24, 2015 04:17 PM
bmxer4it
Aug 19, 2012 07:58 PM
zanelefko
12
Nov 20, 2011 12:37 PM
honki24
Dec 20, 2006 09:43 AM
