JDM rear reinforcment parts... HELP...
Did you read this thread?
I personally don't think its worth the $$$ to import the JDM parts over, when the USDM parts work w/modification. None the parts you listed will even mount the JDM license plate bracket. There is U-shaped sheet metal on the rear of JDM cars that the USDM don't have due to the crash bar. The sheet metal on the JDM cars is what allows the JDM license plate bracket to be mounted. Also note two sheet metal tabs coming off the rear corners, these also help mount/stabilize the JDM bumper on the bottom. USDM cars don't have these sheet metal tabs of coarse.
64001 = MR520343 = JDM rear bumper reinforcement
64410J = 6430A121 = flap, rear end panel (not for sure WTF this is/does?)
80506 = 6430A065 = license plate light bracket (requires different lights than USDM too!)
List of part numbers for reference:
6410A380WA JDM EVO 9 rear bumper
6415A011HA JDM EVO 9 rear bumper cover
MR520343 JDM rear bumper reinforcement
MR574335 plate, L upper same as USDM
MR574336 plate, R upper same as USDM
MF243623x2 bolt rear bumper
MS240141x2 bolt rear bumper for upper same as USDM
MB229232x4 rear bumper gasket same as USDM
MS440522x4 nut rear bumper same as USDM
MF455390x7 tapping screw rear bumper
MR396855x4 gasket rear bumper same as USDM
MS470075x3 clip rear bumper
6430A121 JDM flap rear end panel
MB325298x2 clip rear bumper
MR415259x2 clip rear bumper
6430A065 JDM license plate lamp bracket
6410A196 JDM bracket rear bumper
MS240121x2 bolt hold license plate bracket to rear bumper sheet metal
6410A356 JDM reinforcement face support side
6430A068 JDM license plate bracket
MR485699x2 JDM license plate lamp kit
8518A031 JDM rear wire harness (not for sure if this has same connector as USDM)
ZanarkO
15
Jan 10, 2012 10:01 AM
RussellM
MitsubishiParts.net - WA
16
Nov 4, 2011 12:59 PM
Boost3dxEvO
56
Feb 17, 2009 08:28 AM
201Motorsports
Evo 'For Sale' Exterior Styling
17
Jan 30, 2008 01:59 PM
