Brake question, passenger side getting hotter
What would make my passenger front be heating up more then the driver front? Is it because of the layout of spring mountain? The hot pressure in the tire always seems to be higher on the pass side, and the air is REALLY hot coming out when bleeding. Also the caliper on the pass side is turning brownbo ALOT faster then the driver. Drivers side actually still looks pretty normal. Anyone have any ideas? Im running Motul fluid, PFC 2 piece rotors, goodridge lines and ds2500 pads. Suspension is stock bilsteins with swift MR springs. Ordering a set of dedicated track pads for up front soon, pf97's or 01's most likely.
Thoughts?
Thoughts?
Forgot to add, I dont trail brake at all. I stab them hard before apex, downshift, and turn in. Accelerate out. I know spring mountain does have a couple long left sweepers that I am getting alot of tire squeel out of, could that be it? Turn 3 before ego comes to mind.
No brake fade whatsoever, havent had any problems. Just curious.
have you taken the dust guards off?
I dont think I would worry about it as long as it is not a safety concern in a way that it would not allow you to control the car..
alignment, tire pressure, tire temps.....however usually its to much speed through the corner for the tire.
Tire squeal is a good thing anyways Chris
Nope havent taken the dust shields off, and heard you shouldnt or you could burn up the ABS wire. Next on the agenda looks like Kyles brake cooling kit hehe. The rotors do seem to help, after 3 full track days thats not very brown. Ive been really good at just stabbing the brakes and not riding them though.
Thanks Bryan, makes me feel like Im doing something right if thats a normal occurence then hehe.
I have an RS but all the tracked ABS cars I know burn through pads quickest on the passenger front, usually the inside.
In fact, looking back through a couple videos, I tend to lock the passenger front first. I think that the brake line from the proportioning valve to the passenger front is shortest on the RS.
Also, the correct order for bleeding is passenger front last, so that's another clue that it's the shortest line.
aggieEVO
12
Apr 7, 2015 07:13 PM
20psiMR
For Sale - Wheels / Tires
14
May 22, 2010 09:42 AM
NocturnalEVO
Nov 29, 2004 04:46 AM
