My Evo X at Sebring
My Evo X at Sebring
Here's a video of me this past weekend at Sebring International Raceway. What an amazing track!!!
www.youtube.com/watch?v=1JGjlZPogdE
So, is the track that bumpy, or is the camera mount just a bit shaky?
It's very bumpy. I miss Sebring, I gotta get back down there at some point. Critique wise keep working on smoothness and turn in/braking points. You're a bit early on some and a bit shaky on others. 450 in a 3500lb car isn't exactly the easiest thing to learn on and the aids are hiding most of your mistakes.
Thats Harrys Lap timer petrol head edition.
Yea its bumpy. Turn 17 the car skips while turning lol.
I agree. I do have a lap after that with better and smoother turn in points. What do you mean shaky and what aids are you speaking of? I am braking early to not kill the brakes. With the power and all that weight its really hard on the braking system.
Thanks for the critique, those are the things i look for from others to get better. I had what would have been atleast a 1 sec better lap but was hindered by fuel starvation coming out of turn 1. I will post that video too.
A couple of times you caught yourself turning in too early so you swung back and then turned in which messed up the track out and then the next two corners, etc etc. It's all in practice. But the car itself has a metric ton of driver aids - SAWD/AYC/EBD/blah. So if this is your first times on track then the X is hiding even more mistakes then you realize. Smooth in our cars isn't hard. Smooth in say an s2k or mustang is another story. If you get the chance to drive something else give it a go to feel the difference.
Depending on your build you may also have some weak points which are making smoothness difficult. Without knowing the rest I'd say bring the power down to the 350 range and work on your grip and brakes.
I believe ppl are confusing smooth and lines as the same thing.
My car is at wastegate pressure making that power.
Smoothness is an operation of the entire corner (brake, gas, steering, angle, lines) so ya keep going and you'll nail that down for that track.
However for power that doesn't tell us much. Wastegate pressure and what a 70mm? Stock turbo isn't gonna make 450 WHP at 17psi. Also suspension and settings as many have beaten that horse to death and can tell you by memory what will work best, if you want to know. For reference I was 340hp and running 2:26's there when I started out.
Suspension: Flatout Suspension 5700 coilovers (1 way, rebound) 10k F 11k R, Eibach F&R sways, whiteline roll center, rear camber arms and rear endlinks, dme toe arm.
Front: -2.2 camber .03 toe in
Rear: -1.5 camber .02 toe out
Brakes: Carbotech xp10 F xp8 R, MR rotors F stoptech R, SSB brake line, brake ducting, was using motul, switched to RT700 today.
Car weighs about 3750-3800 with me in it.
Do you have a video of you at sebring? what tires were you running and what does the car weigh?
RT700 supp. is good stuff, may want to jump up on the carbo's to 12's or 20's with your weight if you're experiencing glazing or fade still even after the fluid swap. Camber can also increase as you get more seat time and more sticky tires. You deff need a diet on that thing to take pressure off of everything, with that power and that weight you'll just burn through the consumables.
Totally agree. One of the best things you can do to these cars if you're going to start tracking them heavily is weight reduction. I dropped almost 300 lbs from stock (I'm currently at the lowest allowable weight in my class) and have noticed a huge difference not only in performance, but also in things like tire and brake pad wear. I feel like my tires take longer to get greasy and I can get more heat cycles out of them. Also, while we're talking about Carbotechs, my experience has been that even the XP12's don't stand up to a stock weight EVO very well. Not unless you have some efficient brake cooling. I can get away with them on slower tracks (such as LRP with only one threshold braking zone), but at WGI I will start to get splotchy pad deposits on the front from overheating the pad if I'm not careful.
You can also add a bluetooth OBDII dongle to Harry's Lap Timer and really make your videos cool. I use the one by GoPoint.
Also, if you can afford it, a nice GoPro or Sony Action cam really makes the video smooth over the phone camera. I use a Sony Action cam here too.
Harry's is an incredibly powerful app and he keeps adding new things all the time.
Here is an example...
What are some of the stuff you guys did to get weight down? Besides buying expensive lightweight parts LOL
https://youtu.be/p1hZ21BJLFU
Also how did you overlay the data to the go pro video? or is that on a cellphone?
Thanks!
