The evolution of my Evo IX RS Wicked White
#392
Nice. I will definitely be doing that before dumping more money into my 8/9 brake setup.
#393
it's fairly a cheap bbk setup. only thing is it't not reversible if you want to go back to evo 9 calipers. i was thinking machining some sleeves for the mounting hole if i want to put the evo 9 calipers back on for 17" winter wheels for ice racing. which wouldn't be hard to machine. but i decided to just get stock evo x 18" wheels to use for ice racing. also you still have to use the expensive stock size pads. most after market bbk use cheaper pad size. and you do have the advantage of stock evo x rotor option. should be pretty cheap from rock auto for one piece rotors. the cheapest aftermarket MR rotor rings i've found are $400 for a set of two.
#400
Looks like you need studded tires...lol
#401
yeah, i'm running in the non studded class. they combine the studded and no studded class in the same race. it's only my second ice race every but i was told that conditions was as bad as it can get since there was no snow, just smooth ice. the snow you see is really just ice chunks from the big studded class. it doenst pack down and you grip like real snow.
