TWM Performance FULL Replacement Mitsubishi Evolution X CAGED Short Shifter!!!
--------------> ANNOUNCEMENT<---------------
Hi Everyone,
Following some testing by forum members, we've been able to confirm that the TWM Performance FULL Replacement CAGE Assembly will fit ALL Other Aftermarket SHORT SHIFTERS! So everyone that was waiting to see if this would fit the shifters they owned that were not TWM Performance CAGE Replacement can now place their order!
http://www.twmperformance.com/shorts...rtshifters.htm
If you have any other questions, please let us know!
Patrick
Team TWM Performance
****ULTIMATE Full Replacement Short Shifter for YOUR Evo X by TWM Performance ****
Hi Everyone,
After a LONG and anticipated wait, it’s FINALLY here! TWM Performance introduces the NEW Full Replacement CAGED Short Shifter for the Evolution X! TWM Performance Mitsubishi Short Shifters are the ULTIMATE Short Shifters for YOUR Car, but we’re taking it one step further with the FIRST Full Replacement Short Shifter for the EVO X, EVER!
So a little bit about us, and then about this kit, why we designed it, and what the benefits are.
--- TWM Performance and the FULL Replacement CAGED Short Shifter ---
At TWM Performance we’re always looking to push the envelope of design and ingenuity. It all started back in 2009 with the FIRST true Full Replacement short shifter for the 8th Gen Honda Civic. The product was instantly a hit and we had a hard time keeping the units in stock. It has now become our BEST SELLING Short Shifter that we offer, and people continue to rave about the difference the unit makes in the drivability and enjoyment of their vehicles.
Then we went on to create a similar unit for the MazdaSpeed 3 which was again a HUGE success. So now, we’re ready for another homerun with the EVO crowd
--- The EVO X Full Replacement CAGED Short Shifter ---
The benefits are simple. Basically this kit Completely replaces the OEM plastic shifter housing with an All Steel Construction and uses our current TWM Performance EVO X Short Shifter! That means all play in the plastic assembly is eliminated, creating a more direct and precise shift feel. In addition, the center OEM pivot cup is replaced with our TWM Performance Center pivot system which has tighter tolerances than the OEM piece, which again means less play in the assembly, and a more direct shift feel.
Finally to optimize every aspect of the Full Assembly, we’re using Ball Bearings in the Side Arm to make for the smoothest shift possible, every single time! In short, this kit is GUARANTEED to COMPLETELY Revolutionize the way Your EVO X Shifts!
Here are the specs for the TWM Performance Mitsubishi Evolution X Full Replacement Caged Short Shifter:
Features:
- 30% throw reduction (uses TWM Performance Evo X Short Shifter)
- 1.5 inch Height Reduction
- All steel construction
- Includes solid Base Bushings
- CAGE is compatible with existing TWM Performance Short Shifter
- Available to buy CAGE only or combo of CAGE + TWM Performance Short Shifter
- Available in combo with Cable and Transmission Arm Bushings
- Lifetime Warranty
Fits:
-Mitsubishi Lancer Evolution 10
In short, the TWM Performance Full Replacement CAGED Short Shifter will remove play from your OEM shifter thereby increasing feel, precision and accuracy of Your Car’s shifts! It is the ONLY Shifter Solution on the Market to completely replace the OEM Shift Assembly, and get the MAXIMUM Performance out of your EVO X!
So now on to the important part! The Short Shifter is now on Pre-Order! This means that the shifters are currently IN PRODUCTION and will be shipping out on the FIRST WEEK of the OCTOBER! We will be giving SPECIAL PRICING to people who place their orders on the PRE-ORDER to be shipped on the first week of October!
PRE-ORDER SPECIAL PRICE:
-Full Replacement CAGED unit ONLY (TWM Performance Short Shifter Bolts in): $249.95
-Full Replacement CAGED unit COMPLETE with Short Shifter: $409.95
Getting on the pre-order will insure that you get the Very FIRST batch of shifters to market! To get on the PRE-ORDER, simply Place Your Order at the Link Below. You’ll be put on the list of the first Short Shifters to ship!
-TWM Performance Full Replacement CAGED Short Shifter --- CLICK HERE To get in on the PRE-ORDER!
Also be sure to check out our Premium Weighted SHIFT KNOBS available in a combo deal with the Shifter at the link below! You can SAVE up to $30 on the purchase of Your Shift Knob!
www.TWMShiftKnobs.com
Feel free to ask any questions you may have by posting in this thread, sending us a pm, sending us an email (sales@twmperformance.com), or by giving us a call toll free at 1-877-655-0540.
Thanks!
Patrick
www.twmshiftknobs.com
Hi Everyone,
Patrick
Hi Everyone,
Features:
- Lifetime Warranty
Fits:
Thanks!
Patrick
That's correct the height is not adjustable. In the feeler thread, we had spoken about releasing a tall short shifter, but we've decided to forgo that option. So if you're looking for a taller shifter shaft, the Shifter Extender paired up with this is an awesome setup
Thanks! For the RHD cars, we can't source a car here to test it, BUT we're 100% sure it will fit due to the dimensions we've seen in the past. We'll be adding the RHD option up shortly!
Yes! Everything will fit over like Stock!
Patrick
