WORKS Aperture Throttle Body
i want to buy this throttle body and i am going to pre mail the core i am unsure as to exactly what i have to do and also is there a extra charge for the throttle body with the sensors
thank you Bill
thank you Bill
Bill,
If you go to our webstore in the EVO VIII/IX section under Engine and select the throttle body the default should be pre-mailed core. We normally ship these out without sensors unless the customer specifies otherwise, so be sure to pull the sensors off of your throttle body core before sending it in. Also specify in the notes field whether the throttle body is for an '03/'04 or an '05/'06 as there was a slight design change.
If you have troubles online, just call in and we can process the order over the phone no problem.
415-226-2500
thanks,
415-226-2500
thanks,
is there any thing special i should put on the box or do you guys send me a box to send the stock throttle body to you guys
We do not provide you with a box to ship the core in (just due to added shipping costs).
The best thing to do is just give us a note in the box that says, pre mailed core with your name and phone number. Please use bubble wrap or something similar to package your throttle body in when you send it to us, just so none of the hose fittings poke through the box.
OneCrzyEvo21
Jun 10, 2015 08:52 AM
MitsuJoe
11
Aug 29, 2011 08:09 PM
