Throttle Body Removal
Old Dec 3, 2008 | 01:52 PM
orangeorphan's Avatar
I am trying to remove my throttle body to clean it, but can't figure out how to remove the cable that connects to the acceleration pedal. Help please.
Old Dec 3, 2008 | 02:14 PM
ambystom01's Avatar
It should be attached to a coil-type device. The cable simply unattaches from that.
Old Dec 3, 2008 | 03:29 PM
nope the cable is attached to a piece of plastic that is connected to the coil. The cable does not detach from the plastic though. I just cleaned it while it was still connected though. If anyone can tell me the proper way to do it I would appreciate it.
Old Dec 3, 2008 | 05:13 PM
ambystom01's Avatar
It should simply unhook from the coil. You may have to move/twist the coil a bit.
Old Dec 3, 2008 | 05:39 PM
TheShortBus's Avatar
yes it does unhook.
push the plastic piece to the left to give the cable some slack. then you should be able to thread it up and out the side of the plastic piece.
if you look at it closely its easy to see how.
EVOjunky
30
Feb 24, 2017 04:42 AM
rm4g3d0n
Mar 26, 2015 01:22 PM
bckeye
Aug 30, 2014 05:26 PM
2009GRAYGTS
Lancer Engine Tech
Aug 20, 2009 06:23 AM
hamflex
Dec 15, 2006 02:37 PM
