Interior Help
Interior Help
How do i remove the A- Pillar on the Passenger side (i'm pretty sure thats it) and the front plate where the Cd player is.... i have wires hanging about because the guy before me had XM radio and i'm not paying for it so the wires just hang about and i want to take them out.
The A-pillars just pop out. Start at the top and carefully work you way down. Don't lose the metal clips. As for removing the radio/climate control trim, do the following
1. Remove the climate control knobs (just pull hard)
2. You'll see two small screws behind the temp knob and vent knob, remove these
3. Starting at one edge and working your way around, carefully pull out on the trim piece. There are about 8 snaps that need to be pulled out around it. Take your time, use a screwdriver with a cloth on it if you need to, but try not to scratch your interior.
4. Don't lose the metal clips.
LOL otter,
I've already accomplished this task... but i do want to know what brand/color... i'm going for a Either diamond white with Dark metallic blue accents or vice versa...
So i'm thinking i'll paint some pieces dark metallic blue and some Diamond white.
