HELP!! sway bar Q?
Old Apr 13, 2005 | 08:31 AM
xtianLANCER04's Avatar
Question HELP!! sway bar Q?
hey... i have an 04 lancer ES..and im looking forward to buy a oem (stock) rear sway bar w/ perches from an 04 RA.. the question is..since my car dint come with it..
--would it fit? (direct bolt on)
--would it help? or make a difrence?
let me know guys.. thanks again! i wish it would fit.. to better my car a lil bit more..
Old Apr 13, 2005 | 12:08 PM
anyone??
Old Apr 13, 2005 | 12:13 PM
rhyzin's Avatar
they're the same as the OZ rear bars. goes in fine.
Old Apr 13, 2005 | 01:25 PM
does it work? i mean..is there a difrence?
Old Apr 13, 2005 | 01:49 PM
rhyzin's Avatar
a few have posted of the install. run a search. i wouldn't know as well since mine came with rear sway bars.
captain150's Avatar
You should notice quite a difference between no bar/13mm bar. I am putting in the progress 22mm bar, even bigger difference
Old Apr 13, 2005 | 11:13 PM
Myszkewicz's Avatar
They make a 22mm bar? The Progress bar I've got is 19mm.
The one above it is the stocker. It was 12 or 13mm.
Old Apr 14, 2005 | 12:12 AM
captain150's Avatar
Could be, I heard 22mm... According to Mitsu, the stock is 13mm.
RRM is it 19 or 22mm?
Wait, I ordered the RRM one, I was sure the one RRM sells is the same as the progress one, or is that wrong?
Old Apr 14, 2005 | 12:34 AM
Myszkewicz's Avatar
I got mine from RRM. So far, I'm very happy with it. I was throwing it around some curves on my way home from work, and swerving back and forth out on some backroads, just to feel what no body roll feels like.
Old Apr 14, 2005 | 08:37 AM
403RA's Avatar
This sway bar is next on my list of upgrades. Just wondering if I should also look into the lowering strings from Progress. What is the best, just the springs, or just the sway bar? Are both a kick @ss.
Or should I consider tie bars, I read that a lower and upper tie bar in the back with the sway bars to too much?
Old Apr 14, 2005 | 10:35 AM
BLKRalliArt04's Avatar
You want the best? get the tein coiloveres, progress sway bar, pdxralliart's lower tie bar, and youve got ONE HELLUVA FUN car to drive.
Old Apr 14, 2005 | 10:37 AM
Myszkewicz's Avatar
I'm still running the stock springs. I'm considering getting the Progress springs. I have the upper and lower tie bars, though, and I don't think it's too much.
Old Apr 15, 2005 | 02:19 PM
403RA's Avatar
So u got both tie bars and the sway bar? How's the ride?
Old Apr 15, 2005 | 02:32 PM
Myszkewicz's Avatar
Doesn't feel much, if any, bumpier than stock. It definitely helps keep the car level in turns.
Now I just want some stickier tires, and better brakes, and I'll be happy for a while.
Old Apr 18, 2005 | 12:15 AM
captain150's Avatar
So is the progress/RRM bar 19mm or 22mm?
