How to eliminate automatic Day Time Light
sorry man but i was looking the pic of your ecu, and i dont have an idea, it does not look a little similar to mine, i dont know if it works like mine, but my DRL are controled by a computer (the board conected to the plug) i think you should need to go with a good electro-mechanic
hey black rally, which wire did you unhook
today my green ecu came in from ebay so i could disable them, so i decied to solve this once and for all, and took pictures of the inside of my red ecu.
http://morpheus256.is-a-geek.com/lan...u/CIMG0292.JPG
http://morpheus256.is-a-geek.com/lan...u/CIMG0294.JPG
http://morpheus256.is-a-geek.com/lan...u/CIMG0295.JPG
this may help ALL the canadian RA owners (except for me since i now have a green ecu and could care less :P)
Finally, some good pictures! Excellent.
Should just be a jumper from the pin for the collector on the FET to the pin for the emitter. The white wire is the base, which controls the FET. All it does is allow power to flow from the collector pin to the emitter pin. Unplug the FET completely, and put a jumper between where the red and blue wires plug in.
Morpheus, can you try that and let us know?
well, id rather not fry the one and only red box i have lol. if black rally could open his up and grab some more pictures that would be cool.
also, if you need any REALLY high res pictures i can take them at much higher resolutions.
