Water pump failure at 45k! Replace info?
Old May 10, 2010 | 07:58 AM
04rallikid's Avatar
Alldata didnt have the info I need, about to check chilton library but I doubt it will be helpful. Anyone do one before or work at a mitsubishi dealership? Heard a funny metalic tinging but drove fine and temp gauge was good. Seems like my bearing failed then my seal or vice versa, made it home ok, it was pissing all over the driveway, saw the water pump pully wobbling then shut it off. The book says 2 to 3 hour job.
Old May 11, 2010 | 11:01 PM
Myszkewicz's Avatar
It'd take a heck of a mechanic to do it in 2-3 hours. You have to basically do a timing belt change in order to change the water pump. The pump body is behind the timing belt.
If it was my car, I'd do the timing belt change now. You'll be due for it in 15k anyway, might as well do it now and forget it for another 60k.
Old May 12, 2010 | 07:17 AM
04rallikid's Avatar
I opted out of the timing belt change, I can do that another semester at school. I found all the info I need at chiltonmanuals.com, and when I read I had to remove the timing belt, I opted out and took it to the local garage, thought the water pump was going to let go on the drive down. Shop said $400.
danfalcas
Feb 18, 2016 03:05 PM
real fast
20
Aug 5, 2015 01:39 PM
krose20
Lancer How Tos / Installations
Aug 14, 2014 12:30 AM
90zcrex
10
Apr 30, 2013 06:09 PM
Supramane69
11
Jul 2, 2011 10:17 AM
