shift boot
Old Sep 1, 2010 | 09:36 PM
Jabl3s's Avatar
shift boot
how do you remove the shift boot/install the new one? Thanks in advance
Old Sep 2, 2010 | 10:18 AM
Flip's Avatar
i believe there is a plastic push-in tab down by the pedals, just follow the console down and youll find it, and i think theres one on the passenger side as well, carefully take those out, remove the ash tray, cig. lighter, shift knob, then really easy use a flat tip screwdriver and pop off the silver base, just follow the egdes with the flat head, then i believe there are 4 screws that hold a white plastic piece that has the shift boot stapled or hooked onto it
sorry if this is kind of vague, i haven't done this in a long time, just going off the top of my head right now, if i remember more ill post it for you.
-Flip
Old Sep 2, 2010 | 08:10 PM
lancer758's Avatar
haha those little prongs that hold the silver ring on are way weak so be careful i broke all mine getting it off
Old Sep 3, 2010 | 10:09 AM
lanzerralliart's Avatar
EvoM Super Moderator
Here's a pic I snapped when I was installing my shifter base bushings....I thought it might help..
Old Sep 3, 2010 | 09:55 PM
Jabl3s's Avatar
I appreciate it everyone. Thank You. Now i just have to decide which boot i want for sure.
Old Apr 22, 2012 | 01:29 PM
waterlooLancer's Avatar
I tried the above steps and for some odd reason I am having difficulty taking off the passenger side of the console. The rest is loose and ready to be removed. Are there any clips on the passenger side? I don't want to apply too much pressure and break something. Thanks!
Old Apr 23, 2012 | 04:34 AM
CrAnSwIcK's Avatar
to change the shift boot, you only need to remove the cover, not the whole thing....it just clips on...
Old Apr 23, 2012 | 06:12 PM
Sorry for being a n00b, but which cover? The round cover around the boot? Thanks!
Old Apr 23, 2012 | 09:31 PM
CrAnSwIcK's Avatar
no, the whole top of the shift console just pulls off...you know? the grey part...if you pull the ashtray out you can just grab a hold of it and pop it off...the hard part is disconnecting the wires for the lights and power in the ashtray and cigarette lighter...from underneath you remove the screws that hold the shift boot in place, that ring around the boot is purely decorative, and is like riveted on or something like that..check out lanzer's pic above, you can see the white clips that hold the cover on...you need to take the whole thing off like he did you change the shifter base bushings, but again for the boot, just pop the cover off..
Old Apr 25, 2012 | 08:20 PM
Thanks for the replies and suggestion. I'll try to open the top half once my new Shift Boot arrives. Will post back if I run into any issues.
Cyrax91
Nov 21, 2016 07:20 AM
ekizenbe
Dec 31, 2013 01:50 PM
pedalhead_267
May 1, 2012 06:02 AM
ch1215g
Feb 13, 2011 03:08 PM
JoNaH
11
Feb 13, 2011 12:12 PM
