Engine Dress up tips?
Old Oct 12, 2004 | 08:20 PM
bruce988jl's Avatar
I painted my oil cap.. just the inner circle.. red to match the strut, and i have the RRM SRI intake that's red too, and hopefully i'ma be painting some other parts of the engine red as well.
Old Oct 12, 2004 | 08:31 PM
ski10804life's Avatar
my engine looks awsome i will get some pics sometime
Old Oct 12, 2004 | 08:42 PM
SeanT's Avatar
I am thinking about painting my engine and planned on using this paint:
http://www.duplicolor.com/products/engine.html
Any suggestions on whether to use Engine Enamel or High Heat Paint?
Old Oct 12, 2004 | 11:39 PM
bigdoggy_dog's Avatar
I'm not sure how hot it gets under the hood but the "high heat" is good to a lot higher temp. With the enamel you get a lot more variety of colors. I'd probably go with the enamel, but I'm curious what others have to say on this.
Old Oct 12, 2004 | 11:52 PM
OZrallyats's Avatar
Has anyone yet actually reported their fans melting when they took the heat sheild off, I have the RRM header coming, and I would like to show it off with the shield gone.
Old Oct 13, 2004 | 05:54 AM
Daddymac's Avatar
I've had mine off for a while....no problems so far.
Old Oct 19, 2004 | 02:11 PM
lrh35's Avatar
I did this for under $15
Attached Thumbnails Engine Dress up tips?-ralliart-5.jpg   Engine Dress up tips?-ralliart-6.jpg
Old Oct 19, 2004 | 04:20 PM
otter's Avatar
EvoM Administrator
You'd have to check with the lancer guys. I know on the RA, the header tubes get pretty close to the fans, and some of the DSMs would melt fans.
Old Oct 19, 2004 | 04:40 PM
Myszkewicz's Avatar
Originally Posted by otter
Some of the DSMs would melt fans.
Only when running large turbos, so the turbo was up close and personal with the radiator fans. I ran a 16G in mine, no heat shield, and had no problems with my fans melting, even with a thicker radiator in there.
Old Oct 19, 2004 | 06:59 PM
MivecSPEED16's Avatar
I've hade mine off for a long long time and no problems (knock on wood)
Old Oct 19, 2004 | 07:25 PM
otter's Avatar
EvoM Administrator
Could very easily be an blown out of proportion problem then
Old Oct 19, 2004 | 08:06 PM
ralliartracer's Avatar
What i wanna know is can you get high heat engine enamel and pain the OE header? I want to paint mine chrome. Would that work?
Old Oct 19, 2004 | 08:33 PM
OZrallyats's Avatar
You should save up and get a header. Looks better plus performance
Old Oct 19, 2004 | 08:35 PM
Myszkewicz's Avatar
You might find paint that'll withstand the heat, but you won't find chrome paint that looks good and will withstand the heat.
Old Oct 19, 2004 | 08:52 PM
The ralliart does not need an aftermarket header. It cannot be improved much more. It would be a waste of money buying a new one.
