Mud guards?
Old Jul 13, 2005 | 01:36 PM
ddcha's Avatar
Mud guards?
Anyone put mudguards on their RA?
(1) Which ones?
(2) How much?
(3) How's installation (drilling required?)?
Old Jul 13, 2005 | 02:32 PM
reTro's Avatar
I don't think there are any mudflaps that are a direct fit for our car... but maybe with a little modification, you could get these to fit?
http://www.lancershop.com/customer/p...?productid=611
Old Jul 13, 2005 | 04:00 PM
otter's Avatar
EvoM Administrator
The only ones I know of that are direct fit are the OEM ones you can get from your dealership or www.mitsubishi-parts.net
Other ones can probably be modified to fit without much trouble.
Old Jul 13, 2005 | 09:32 PM
AdamRA's Avatar
These would take some modification for sure especially on the rear.
Old Jul 14, 2005 | 05:26 AM
WoRkZ's Avatar
Post
Yeah, wild_child and I we looked at these and for his car (he went for the rally look) and it's not gonna bolt right up, I can assure you. In fact, he decided to have them custom made instead... and it was cheaper too!
Old Jul 14, 2005 | 07:10 AM
skylancer's Avatar
(1) Which ones?
(2) How much?
you want mudguards or mudflaps?
mudguards you have to get from factory....don't know the price because never want to put mudguards on my ride
mudflaps you can get the one for Evo 7/8 should fit......but they are very costly...the cheapest I saw is $100 ...& some are more than $400...I've been looking for the mudflaps too....especially the one with the word "RALLIART" on it, it's very rare!!
Dre 8472's Avatar
I've been thinking I need these. Its always the first place to get dirty on my car!
Old Jul 14, 2005 | 07:13 AM
AlkalineTrio124's Avatar
I have a set of black mudflaps... They have "RALLI///ART" written on the bottom in white... If someone's interested me they can PM me... I don't have any pictures and haven't listed it in the "for sale" section... If someone doesn't give me an offer, they're just going to go in there!!!
Old Jul 14, 2005 | 07:19 AM
WoRkZ's Avatar
Post
Nope, you have to modify them because the screw holes are not at the same place (some aren't even near!). It's especially true on the back... but the front is not an instant fit either.
Old Jul 14, 2005 | 09:51 AM
bruce988jl's Avatar
it's just a matter of drilling holes right?
Old Jul 14, 2005 | 10:46 AM
WoRkZ's Avatar
Post
Yeah, but then you're left with a mudflap with apparent holes (you may not care that much though) ... but I would be a lot more worried that drilling holes in the plastic of the mudflap can lead to early cracking. Some materials cannot be drilled through without causing micro-tears... most of the time when the stuff is hardened through a high-heat process.
But hey, it might also come out very nicely and be as durable as if it was made for the RA.
Old Jul 15, 2005 | 08:21 PM
bruce988jl's Avatar
well i figured my friend has some extra sheet metal lying around (thin stuff) if i can glue a plate cutout with predrilled holes (through the plate and the mudflap) maybe it'll support it nicely. And the metal plate will probably be inbetween the mudflap and the bumper...
i don't know, it's just an idea.
Old Jul 15, 2005 | 10:43 PM
WoRkZ's Avatar
Lightbulb
Not a bad idea actually... if you put the plate after the mudflap though (you hold the mudflap on the body by adding the plate before you insert the screws). It would have to be painted black... but this would be a really good way of installing them. That way they're not going anywhere for sure... and I can't see the plastic cracking either, because now the pressure between the plate and the body prevents the lateral stress in the material.
Nice bit of thinking there... and you know what? You just might have solved a home improvement problem I was having the other day too!
