Front license plate relocation?
Old May 9, 2009 | 07:00 PM
NorCal Lancer's Avatar
reviving this thread so I don't have to start a new one and get bashed on for not searching!
anyways, here's the deal. My front bumper has no holes in the front, right now there is currently no front plate on! Well it happens that a douchebag cop decided to pull me over for no front plate and window tint -_- after like more than a year, i didn't even do anything wrong and I got pulled over... I wanted to relocate the plate to the side, so can I use the evo one? and if so, is there a difference between the evo 8 and evo 9 bracket? I really need to find out ASAP becuz I need to get my ticket signed off by the 19th of May -_- so I want to order that bracket or try and find one on evom for cheap ASAP! thanks!
Old May 12, 2009 | 08:39 AM
please, I really need an answer to this question, so if anyone knows then please tell me so I can act on this ASAP. I only have a week to get my car fixed -_-
Old Mar 7, 2010 | 09:59 PM
christianrod's Avatar
so did you ever get that bracket mounted on the side? if so what evo plate did you use?
Old Mar 8, 2010 | 03:06 PM
Nope, i just used double sided tape, haha. I'm pretty sure its the evo 8 bracket though
Old Mar 9, 2010 | 12:32 PM
can you post pictures of what it looks like? haha im curious. and you just covered up the holes in the middle?
Old Mar 30, 2010 | 12:55 PM
BlackRaven's Avatar
I need some help on this too.
The Evo 8 and 9 brackets front plate mounts are different. The 8 mount has the big plastic piece, and some metal bracket that mounts behind it. The 9 mount, I don't believe, has the supplemental bracket.
Does anyone know the part numbers of what's all needed for the 8 mount? I have the big plastic piece, but none of the supplemental brackets & hardware, and I can't mount it to the bumper without them...
Old Mar 30, 2010 | 07:36 PM
rrd's Avatar
rrd
there's no metal brackets on the evo 8 one, i'm pretty sure they are the exact same
i got the evo 8 one for mine and it fit the curvature of the bumper perfectly, i mounted some L shaped brackets from lowes to the back of mine and drilled it in on the underside of the opening in the bumper/fog light area so i could take it off if i wanted and voila no holes in the front, they are hidden
Old Mar 31, 2010 | 05:49 AM
manolo2011's Avatar
i bought an evo 8 one and have it on my Ralliart. Fits perfect and depending on where you install it, it will block or not your foglight...i bought it on a mitsubishi dealership for 25 bucks...
manolo2011's Avatar
no metal brackets...just a couple of Home Depot bolts...that's it....
Old Mar 31, 2010 | 07:01 PM
rrd's Avatar
rrd
here's the photos of mine:
in this one you can see how i mounted it underneath
Old Apr 2, 2010 | 09:49 AM
nice rrd. so you put two L brackets? looks like one bracket is in the fog hole and the other is on the other side of the divider? and hole did you screw the license bracket to the L bracket? is there a hole or did you have to make one?
Old Apr 2, 2010 | 10:11 AM
rrd's Avatar
rrd
yeah one is on the fog hole, the other on the other side
basically i used the existing holes in the license bracket where you would normally screw in your plate. i used a bolt with a locking nut and pushed it through from the back to tighten the brackets on first, so the threads of the bolts are actually pointing towards the front of the license plate, then i just put some closed end nuts on the end to keep the license plate + license plate cover in place
i hope that makes sense
Buru_EvoX
Sep 7, 2016 07:52 AM
Evo_Goodness
Aug 7, 2016 09:52 AM
joshpiger
Jun 30, 2015 02:47 PM
Jlui83
Outlander Sport
Jan 6, 2014 06:47 AM
austere11
23
Oct 4, 2010 12:00 PM
