projector headlights question #5000.
Old May 30, 2006 | 09:54 AM
RaLLi's Avatar
How do I open up the projectors to paint the housing black, and how do I seal them closed again?
Also, I have a white ralliart. What do you think it would look like if I painted the headlight housing the same color as my car (white) instead of black? I think it would look really good and different.
Thanks.
Old May 30, 2006 | 10:50 AM
modelchris's Avatar
yeah, all u gotta do , and there are threads (countless ones) of how to DIY black out headlights; but i won't flame. just set the oven for 276 degrees i believe is the temp- and put each headlight in one at a time for like 4-6 mins. each (on toip of a cookie sheet), take em' out and peal the silicone apart..i used a screwdriver and flatheads. do the same thing to seal them back up - only i reinforced the silicone with aquarium sealant (walmart).
Old May 30, 2006 | 10:51 AM
modelchris's Avatar
as for painting - - i used...****, i forgot what grit sandpaper i used, but pretty much a fine grain grit sandpaper from walmart- and lightly sanded down the chrome or whatever - and used flat black primer paint at walmart - and used up the whole can on that, and bought some bbq grill paint to finish off- in your case, u might just want to get a hold of a paint shop who can match the paint code for your paint finish of your car (white), and have them do it, or whatever.
Old May 30, 2006 | 12:13 PM
MitsuLancerTO's Avatar
here you go:
https://www.evolutionm.net/forums/sh...5&page=1&pp=15
mind you...in order to remove the oem headlights, you gotta remove the bumper. i should be doing this shortly and will have a write up as to the exact locations of the bolts and clips
Old May 30, 2006 | 02:58 PM
RaLLi's Avatar
Thanks alot guys!
Do you guys think painting the projectors white instead of black for a white car will look good, or should I just do them black?
Thanks again.
Old May 30, 2006 | 03:20 PM
lancerman360's Avatar
I have seen white before and it looks pretty good on white cars. black also liooks nice on white cars too. If it were me i would go white cause not eveyone has white. Color matched headlights are cool.
Old May 30, 2006 | 10:26 PM
modelchris's Avatar
on ebay a little while back, they had color-matching headlights; they werent projectors. but they still looked bad ***. so i say DO IT. i think it'll look nice- and if they dont ; u can always paint em' back black or whatever.
