Dash Light Change
Old Jun 5, 2007 | 04:01 PM
ox663bender's Avatar
Dash Light Change
I changed my dash gauge lights from amber orange to blue, I bought the kit from lightrikz, easy install... just dont forget to mark where your niddle sits before you take it off because it sucks trying to redo your speedo...
My question to you all if you have changed your dash lights is how did you make your color brighter... how do you get the yellowish film off the backs or the gauge inserts....?
Old Jun 5, 2007 | 08:22 PM
sP33Dy's Avatar
*** Pointless thread without pics ***
I see no show'n'shining!
Old Jun 5, 2007 | 09:02 PM
RalliArtChink's Avatar
+++++1
Old Jun 5, 2007 | 09:06 PM
sly's Avatar
sly
Old Jun 5, 2007 | 09:17 PM
no actually its not if you read the question you'll find I am not trying to show anything I just have questions... so keep your comments to yourself unless you have answers....
Old Jun 6, 2007 | 02:05 AM
sP33Dy's Avatar
The Show & Shine section is normally reserved to show off your car with PHOTOS!!! ..... posting in the right section next time might of been better Ive not done what u are asking for, and don't understand exactly what u are referring to without pictures to explain!
Old Jun 6, 2007 | 09:19 PM
BlackRaven's Avatar
First, sorry for the big & blurry pics...
I used the edge of a knife to scrape away at the film, then.....
...used a wire brush bit on a rotary tool to "clean it up." Prolly an easier way to do it than that, but just a word of warning if you use the rotary: don't keep it on one spot for too long, because it'll get hot and maybe melt your gauge face.
Old Jun 7, 2007 | 01:24 PM
thanks for the info... did any of your gauges mess up or show false readings?
Old Jun 7, 2007 | 10:11 PM
BlackRaven's Avatar
Nope; for the speedo and tach, I took straight-on pictures with the two little black pins out as a guide as to where the needles should point (this is obviously with the faces still on the gauge cluster). Drove past one of those speed trap things police will set up where you can see your speed...matched up no problem.
The temp. and gas needles have an extra tab that limit how far up and down they sit. To put those back on, I reinstalled the gauge cluster in the car, minus those two needles and without the clear plastic lens. For the temp: I just had to remember where it usually sits after my car's hot, then slide the needle back on to that spot. For the gas: topped off the tank, slid it on to full.
Old Jun 9, 2007 | 10:44 AM
Ralli04's Avatar
got any before and after...or just after...pics??? interested in seeing how much brighter it looks after scraping away that film
Old Jun 12, 2007 | 06:55 AM
Hey do you still have the pics of the speedo? I could realyl use it
Old Jun 12, 2007 | 08:11 AM
DangerousDan's Avatar
read this and the discuss here thread posted by lancerevomr. IIRC the information you require will be here.
BTW, this IS in the wrong section, it should have gone the in how-to subforum.
https://www.evolutionm.net/forums/sh...d.php?t=132611
tunermt
12
Dec 13, 2023 04:12 AM
Eevee
Jun 4, 2017 08:13 PM
cts4g63
Nov 23, 2015 05:09 PM
-francis-
Nov 26, 2011 12:55 PM
lancerMRguy
Jun 29, 2008 07:44 AM
