Lanzerralliart's RALLIART
#46
where did you get your under-hood and the base bearings from? i think im have to hit that up. i have the syncroshift on oder right now, just waiting for that stuff to come in, i have heard good ish about it. nice pics bro, you not using the cf eyelids anymore? notice they werent on with the new hood and bumper
-Flip
-Flip
#47
Thanks for the kind words....
I got the under the hood bushings from zaklee a while back, I picked up the shifter base bushings from a partout from another member(speedsource brand).
I just installed the base bushings. Before the install I grabbed the plastic base and tried shaking it it flexed a little bit but seemed pretty stiff, so I was like ok this seems like a wasted mod on both money and time. After I installed it I tried shaking the base again and it didn't move at all, so I changed my attitude , worth it, the shifts are more precise and smooth. I recommend this mod to any ralliart owner...
I was going to flush the tranny fluid but after going outside I come to find out my friend borrowed my jack stands without my knowledge, *******!! And what really ticked me off is he's in Cuba on vacation so now I have to wait til the 11th do cuss him out and do the flush....grrrrrrrr
As for the CF eyelids I lost one a while back on I95 so I took the other one off. I'm planning on turning it into a switch panel in the cubby hole above the shifter pretty soon..
#48
yea im waiting for my order of BG scyncroshift II to come in. its taking forever!!!
but when it comes in, its tranny fluid change time, i feel my RA def needs it right now...
as for the turning the eyelid into a switch panel, thats sounds pretty awesome, post up some pics when your done, would like to see that
-Flip
#53
I have question for anyone with some experience installing a front tow hook. I've seen one installed to the front crash bar but they cut a hole in it and only bolted it to a single side of the crash bar. I'm planning on drilling 2 holes completely through it and getting some grade 8 bolts , then bolt it up with some locknuts. Or my second thought is to drill the holes a bit larger, pit a steel spacer in each hole rthen the bolts. Sounds good ? This is to be used ( hopefully not) but I want the strength to be there if needed one day. Since I have an aftermarket bumper the oem one is out if the question, it would be destoryed if used. Thanks in advance for any useful info
#54
Hail to the Beard
eww. no wing please.
I was going to ask about this. Why does Lancershop say the fluid is for evo's only?
As for the fluid it's more along the lines of ,lack of knowledge. They also don't list the shifter bushings as for the lancer ralliarts.Checkout buscar racing much cheaper btw...
#57
Hail to the Beard
No worries an evo wing would only go on the car if Santa installed it himself lol....
#58
I mean that lancershop although the name would have you think they know about all "lancers" they do NOT. They don't know about parts that are interchangable for evos to lancers and such
And kao , that sounds like a good proposition, I've talked to LSD once before on the phone. I can't wait for his car to be finished, it's going to be the next Mona Lisa.
#59
-Flip
#60
What was lsd last hitting on the dyno? His car has been nothing short of amazing. Flip I have also watched your car come along, looking good.
And my p.o.s. should be something to keep an eye on, 10.5 : 1 boosted, really hope to crack the 300 mark. After that it only goes up.
Here's a shout out to the O.G. Ralliart Nation.
