home made diffuser
Old Jun 29, 2010 | 01:45 PM
bruce988jl's Avatar
Not much for function since they're way too thick but I guess for cosmetics not bad. I would try to make them have less of a flat/cornered look on the lower portion and the rear portion of it but not bad for something you made at home.
I definitely give you creativity points.
Old Jun 30, 2010 | 05:26 AM
jessep's Avatar
you know now that i think about it" home made diffuser" wasnt the best title for this.
Old Jun 30, 2010 | 05:53 AM
lanzerralliart's Avatar
EvoM Super Moderator
Man I like it , looks near oem, keep it up.
Old Jun 30, 2010 | 06:01 AM
blaire's Avatar
That looks pretty good
Old Jun 30, 2010 | 06:13 AM
BriK's Avatar
Good point. A diffuser implies you covered a large portion of the underside for aerodynamic effect.
I think either "I gave my rear bumper a FauxHawk" or "Homemade upside-down Vortex Generator for the bottom of the rear bumper of my Lancer" would be better.
Old Jun 30, 2010 | 08:59 AM
SyZyGy1394's Avatar
Yup. Also, a diffuser is pretty useless if you have really turbulent air going into it. So you might as well run an entire underbody on your car too.
Old Jun 30, 2010 | 11:39 AM
TriangleChoke's Avatar
Honestly, for a home made project, first attempt. Very good
Only thing I would say is if you have more cut outs, you could sand them down, give them smoother edging similar to a Vortex Genorator, would give it a nice finished look.
Old Jun 30, 2010 | 01:49 PM
blaire's Avatar
I honestly think it looked better white though.
Old Jun 30, 2010 | 03:19 PM
jessep's Avatar
how about now does it look alittle better now with them being 1/2 with a slight round over. and there spaced out pretty evenly the center is 11.5 then the other spaceis are 8.5
(new ones next to the old ones)
Old Jun 30, 2010 | 03:30 PM
tisoy3's Avatar
Not bad at all.
Old Jun 30, 2010 | 05:03 PM
blaire's Avatar
Its a unique and cheap mod even if its just for looks
Old Jun 30, 2010 | 05:09 PM
Ryan.Kauz's Avatar
the only things I could think of for improoving this would be to source black plastic so that if the base color was a better match (yes you would still paint over it, but still)
And also adding a small pin to the sides of the main bolt hole which would ensure that the plastic triangle stays in a verticle position. Wouldnt need to bolt to the bumper.
Old Jul 1, 2010 | 08:00 AM
richscd2's Avatar
wow not bad
strang3majik
For Sale - Cars For Sale
Oct 7, 2015 03:20 PM
strang3majik
11
Jun 25, 2015 03:01 AM
evofan_08
Apr 5, 2013 11:00 PM
evofan_08
Jun 2, 2011 01:53 PM
