Itching to de-rice (remove vinyl)
Old Feb 23, 2011 | 04:31 PM
mmoulton470's Avatar
Hey all, I've been wanting to remove the obnoxious black tribal (that was on my white 05 r/a when I bought it) for a long time now, but I am scared that my paint has faded a little and the paint under the vinyl will be nice and shiny, leaving me with permanent tribal post removal. Has anyone done this before? The vinyl is really big and will look horrible if it is noticeable after it is removed.
Thanks for any insight.
P.S. I am not looking for instructions on how to remove vinyl, so please don't flame me for not searching.
Old Feb 23, 2011 | 05:17 PM
roblaza's Avatar
Your car is white, you should be fine. After you get it off give the car a good buff and you wont even know there was anything on there.
Old Feb 23, 2011 | 05:21 PM
jebus27's Avatar
faded tribal > black tribal
i would get a detail if you notice the fade around the vinyl
Old Feb 23, 2011 | 07:15 PM
Cool, I'll take it off tomorrow then.. Thanks.
Old Feb 23, 2011 | 07:36 PM
monkeyfish76's Avatar
Just get a heat gun and it will come right off. Mine had some Purple flames on it when I got it. It came off with a little heat and then I used some citrus cleaner to remove what little adhesive was left behind.
Old Feb 23, 2011 | 07:56 PM
Raikiri's Avatar
I don't think the fading if any will be as bad as you think it is. Even if it is a good wax should do the trick
Old Feb 23, 2011 | 08:53 PM
lancerralli06's Avatar
I think you should be fine, white is probably the best for removing decals. My RA is black and it had a 6x8 decal on the back from the original dealer in 06' and I just removed it in september of 10'. It had some adhesive residue left so I took some GooGone and cleaned it up in about 10 minutes. Then wash and wax and looked brand new.
Old Feb 23, 2011 | 08:57 PM
Boltz.'s Avatar
FCOTM Winner
White can actually can suck for removing vinyl. It can turn the paint yellow. If you need help you can PM me. GL
Old Feb 23, 2011 | 09:13 PM
Hmm, I've had 3 white cars and all seemed to clean up pretty well, BUT I can definitely see them turning it yellow though depending on how much sun they get and such. All of mine have been Wisconsin cars, so fading probably isn't as much as an issue as sunnier areas.
Old Feb 24, 2011 | 08:29 AM
Darewood's Avatar
Hey mmoulton470,
Good luck with trying to remove the vinyl, from my experience it usually turns out alright. I want to say the paint might be faded around the decal also too, but it will probably fix itself over time. I took off my sunroof wind deflector thing and the paint was a different shade when taken off, but after like a month it blended together.
Also did you buy the car from carbiz in MD?? That ralliart looks really familiar! I remember it because they tried selling it to me when I was looking at the other one they had (which I bought).
Old Feb 24, 2011 | 07:13 PM
Originally Posted by Darewood
Hey mmoulton470,
Yeah, the section that I have taken off so far has matched the paint perfectly I am, however, having trouble getting the leftover adhesive off. I've been using rubbing alcohol/ammonia.. They seem to work equally crappy but do get the job done with a lot of elbow grease.. I'm going to pick up some goo gone tomorrow. Hopefully that will Make it go a little easier.. Also I'm using a blowdryer as I don't have a heat gun but it seems to work.
I bought my car from Fitzgerald auto mall in Frederick, md in may of 2009. It's possible they bought it from carbiz I guess? Its nice to hear about some other r/a owners in md.. I've never seen a single 04-06 r/a other than mine around.
Old Feb 24, 2011 | 09:37 PM
Raikiri's Avatar
yes goo gone should do the trick. however when it comes to removing adhesive when i took off my emblem i just went through my kitchen and found something called soft scrub. it did the trick fairly quickly. it hasnt caused any problems with my paint in that area as long as you wash it off good after you use it since it contains bleach. i wasnt too scared since my car was white anyway. if you're feeling adventurous you can try it out.
Old Feb 25, 2011 | 12:35 AM
Cool, I might try that.. Maybe I'll buy a thing of each and see which one works best.
Old Feb 25, 2011 | 02:14 AM
Goo gone yes, SOFT SCRUB I WOULD SAY HELL NO.
Wicked_Ray
Northeast Region
Jul 18, 2016 06:55 PM
Tribal
May 11, 2016 02:18 PM
Anarchy99
Oct 20, 2009 03:54 PM
blackheart1425
Toronto Lancer Club
14
Aug 30, 2009 05:00 PM
LetsGo82nd
Mar 1, 2009 11:58 PM
