View Poll Results: Lowering...What would you do??
Lower just the front only for an \"even\" look
17
23.94%
Lower all around just a little
41
57.75%
Slam the car
11.27%
Keep stock
7.04%
Voters: 71. You may not vote on this poll
Lowering.....Just the Front
Old Feb 24, 2004 | 10:10 AM
Deltarider99's Avatar
I agree too, I think making the wheel gap ( or lack thereof) on the RA the same would be great. But I'm very afraid to lower anything, after my last car. I changed out the springs and struts on my '02 Cav with H&R/Koni Reds......and the suspension went to hell. All sorts of clunking noises, rattling....
I guess I just want to be sure that when RRM says you can use your stock struts with these springs, are they just saying that to push product, or can it be reasonably comfortable and safe to drive with them?
Old Sep 4, 2004 | 10:01 AM
AdamRA's Avatar
Originally Posted by mitsumichael7
I got a good up close look at the Tein coilovers on the RRM RA yesterday and that is CLEAN! I am thinking about waiting. They did say that the rear will sit a little lower than the coilovers did. But the Teins are adjustable and more $$$. They also said the progerss springs are nice.
This is the route that I will be going, The adjustable ones are pretty expensive but well worth it.
Old Sep 4, 2004 | 11:34 AM
RollerPyro's Avatar
If there's no spring lowering kits that make the ride height even, you can get coilovers with adjustable ride height and even it out that way. If you have the money that's definately the way to go. Since you won't need your stock shocks anymore, they stay new while you drive on the coilovers. If you end up selling the car, you can put the stock suspension back on and say the shocks are new.
Old Sep 5, 2004 | 06:35 AM
Sentinal's Avatar
any lowering you do at all will void your warrentee so if you want to keep it then keep the car stock... as far as trade in goes it will lower your trade in value even if you use the best performance springs out there (I know from experience) lowering the front does give the car a more even look which is nice but if your planning on not keeping the car for long I would keep it stock unless you don't mind spending a lot of money to lower the value and kill your warrentee just so the car looks a lil better
Old Sep 5, 2004 | 08:11 AM
Myszkewicz's Avatar
That's just the lovely Chicago roads.
I've killed a total of 5 wheels on my DSMs on Chicago potholes. Oddly enough, only the wheels were damaged. The tires were always fine.
Yes, I know you're supposed to avoid the holes, but when it's dark, raining, and you're going 70mph they're hard to see. All of those bent wheels happened on my way home from work, at around midnight.
Old Oct 19, 2004 | 10:13 AM
ozrmrlancer's Avatar
Thats how a rally suspension works, you can't lower just the front cuz then you would get some funny handling
Old Oct 27, 2004 | 08:39 PM
ilovecb23's Avatar
if i lower mine, i will only lower the front, i like how low the rear is and how is looks stock
Old Oct 27, 2004 | 08:51 PM
AdamRA's Avatar
This is not a wise idea. This will effect your braking and handling. Springs come in kits anyway so unless someone wants to buy just the rears then you would be out of luck.
Old Oct 27, 2004 | 08:58 PM
yellowmars's Avatar
Originally Posted by lkwdkuraj02
First.......Factory Warranty....I don't want to void that....
Well, buying the car already voided the warranty! So, you might as well do what you want!!
Old Nov 10, 2004 | 06:28 AM
WoRkZ's Avatar
Question
Okay, this will probably establish a new record for the dumbest post on this forum... mostly because I know squat about springs :
Can stock springs be modified so that they are 1/2in lower? I mean, can springs be cut/heated/compressed??? I guess not, or people would be doing that all the time... but who knows.
Now, it's done... I've asked the dumbest question, right? Hey, maybe there's a special gift for that?
Old Nov 10, 2004 | 06:39 AM
Ralliart@PDX's Avatar
You cannot heat or chop factory springs, they are what you call a progressive sping. The coils are more tightly coiled on one end than the other. By chopping or heating you affect the ride dramatically. you could get extreme bounce out of the car and ruin your springs.
Old Nov 10, 2004 | 06:43 AM
WoRkZ's Avatar
Smile
That makes sense... then again, 1/2in? That sounds so marginal a chop...
Well, anyway I'm sure you know much more about springs than me, so I'll deffer to your judgement. Thanks for the answer (and for only laughing at me in private ).
Old Nov 10, 2004 | 12:47 PM
BLKRalliArt04's Avatar
Dont chop your springs, itll send your alignment all to hell. I have known some people who chopped them and they could literally not get more than 5000 miles out of a set of 4 tires because the alignment was soo bad, regardless of how many times you take it to get aligned, if you chopped your springs more than likely it will never get aligned properly again unless you put on a whole new suspension.
Old Nov 17, 2004 | 02:00 PM
TurboWill's Avatar
Tien S-Techs
__________________
Rally Red EVOVIII
