Cleaning the engine bay.
Old Jan 18, 2004 | 03:15 PM
jsfour's Avatar
cleaning the engine bay?
hey guys i lost my oil cap so there is oil in my bay. How can i clean it out the best?
Old Jan 18, 2004 | 03:30 PM
blaze_125's Avatar
Gunk all the way
Old Jan 19, 2004 | 11:29 AM
jsfour's Avatar
bump
Old Jan 19, 2004 | 11:37 AM
Sailorgoon's Avatar
JS, you seem to have missed blaze's answer...
Originally posted by blaze_125
Gunk all the way
Gunk is the name of a solvent that you can buy at any autoparts store. It cuts through dirt and oil like a hot knife through butter. You wipe it on, wipe it off, or hose it all down after letting it soak for a while.
It really works. An alternative is to go to the local car wash that has an "engine" setting and blast the sucker. Make sure not to get any water in the airbox or damage and hoses, and don't do it if you've been driving all day. Hot motor can cause steaming, which can burn you if you're not careful.
Old Jan 19, 2004 | 11:41 AM
zlancer's Avatar
also get another oil cap....btw...how the hell did you loose it...annnd why would you drive it with it off!?!
Old Jan 22, 2004 | 12:11 PM
Deltarider99's Avatar
How to clean the engine bay?
What do you guys use to clean the engine bay when it gets dirty?
Old Jan 22, 2004 | 12:17 PM
gfd205's Avatar
I use either GUNK engine degreaser or a regular engine cleaner from a local parts store or target stores.... Just warm up your car, shut it off, and spray a little water on and then the degreaser and let set for about 15 min. and then spray off. Just dont overuse the water...
Old Jan 22, 2004 | 12:19 PM
misgracyfrog's Avatar
If ur talking about the floor, what I have always used is Suave shampoo. It works good on concrete floors and driveways. Just squirt out some of it on the ground use a bristle broom or scrub brush, work it in add a little water, let sit bor a bit then rinse. If ur talkin about ur engine I use something called Engine Brite, it also cleans out ur oven! gracie
Old Jan 22, 2004 | 12:21 PM
Archangelite's Avatar
i use elbow grease
Old Jan 22, 2004 | 12:47 PM
JWERNER24's Avatar
In Timeout
"Dave's Insanity (hot) Sauce" cleans everything, including grease/oil stains on your driveway. It says so right on the bottle...
Old Jan 23, 2004 | 12:26 AM
ohcanada_00's Avatar
having just had to clean oil and other foreign fluids off my drive way from the fire water and laundry soap works like a charm. It took me about 20 min to some really bad crap off my driveway.
Old Jan 23, 2004 | 12:30 AM
bobaab's Avatar
i used turtle wax to get that nasty thing that they spray on to protect it from rusting..i forgot what it was called but with turtle wax and a little elbow grease, my engine compartment is clean. well, the sides where it's painted at least.
Wyoevo9
Aug 9, 2012 09:00 PM
redevo21
Aug 23, 2007 07:38 AM
poordude
Jun 15, 2007 07:46 PM
mcbrown35
Jun 22, 2004 05:34 AM
