Cleaning the engine bay area
Old Aug 21, 2007 | 09:54 PM
redevo21's Avatar
My engine bay area was beginning to get a little dirty. Was wondering if anybody had any suggestions or precautions to take while cleaning the engine bay. I do have a cone filter on. Thanks in advance for any replys.
Old Aug 21, 2007 | 10:10 PM
Ultimate CC's Avatar
put a towel on the alternator and electronics, a bag over the filter and get some of the engine bay cleaners (many different companies out there) and follow the directions, they work pretty well then make sure you run the car shortly after to dry it all off...
Old Aug 21, 2007 | 10:31 PM
GreyAWD2006's Avatar
I actually use as little degreasers as possible. Make sure the appropriate things aren't getting soaked in water.
I use a good car wash soap and some elbow grease. Some terry cloth towels and a few different soft-hard bristled brushes and you should be all set.
I rinse lightly before starting the car. Then continue with a good rinse down with the car running. Then shut the hood and let the heat build up to dry it off.
Repeat as necessary.
Old Aug 21, 2007 | 11:02 PM
UCLAevoIX's Avatar
wouldn't it be bad to rinse down with the car running or leave a good amount of water on the parts with the car running, because water will quickly cool hot metal (i.e. engine) and can cause damage?
Old Aug 21, 2007 | 11:05 PM
tripperfx3's Avatar
While running, yes, but if you clean it with the car off and there happened to be a pool of water on the heat shield then it'll just boil off pretty damn quickly. Its relatively safe to clean the engine bay as long as you do like mentioned above and protect the electrical components and cover the air filter.
Old Aug 21, 2007 | 11:13 PM
Kevindanger's Avatar
+1
Old Aug 21, 2007 | 11:42 PM
sparky's Avatar
Try Simple Green diluted to 30%. Just spray the stuff on and then rinse it off with a hose. Do it a couple times on succesive weekends. If there are any stubborn spots then go over them with a sponge. This works for me, as it involves little elbow grease and is relatively eco-friendly.
Old Aug 22, 2007 | 01:03 AM
boostless's Avatar
Some of you are acting like the engine can't get wet. Cover the electrical, use simple green or a engine degreaser then spray it off. Itll look like the day you bought it.
Old Aug 22, 2007 | 06:40 AM
Chemwarrior's Avatar
I'm a firm believer in using Simple Green. It's eco-friendly and cleans the heck out of stuff. As far as covering stuff up before you rinse your engine bay I don't think it is necessary. An engine bay is not waterproof to begin with and is meant to get some water in it. Just be careful with the air filter though. Hydrolock can be a biotch.
Old Aug 22, 2007 | 07:18 PM
DBPLAYA00's Avatar
avoid strong degreasers. try not to spray alt. too much. i have seen them fail instantly at work after some degreaser made its way in. if u hav some compressed air dry it with that then run it.
Old Aug 22, 2007 | 07:22 PM
evokel's Avatar
i heard using spray on wax also works....dont know tho
Old Aug 22, 2007 | 07:35 PM
redevo21's Avatar
Thank You for all the replies guys. Greatly appreciated.
Old Aug 23, 2007 | 06:46 AM
S-1's Avatar
S-1
I've always used Simply Green to clean my engine bay. Works great and smells good!
Old Aug 23, 2007 | 06:49 AM
Wallesasuaz's Avatar
a good smelling engine.. that's funny.
Old Aug 23, 2007 | 07:04 AM
stryfetew's Avatar
What about if you had an after market manifold like the infamous megan ?
