04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Finished Custom Kit and tests
Old Jun 15, 2005 | 08:19 AM
Thunder-rush's Avatar
Hi guys just finished tunning my turbo kit . The kit consists of custom exh manifold, T3/4e turbo, RRM piggyback my custom tune flash, 720cc injectors, stock fuel system, large intercooler, 2.5 exh, set at 8psi. Last Saturday the car dynoed at 8psi 253whp with 12.3A/f and then I tunned it down to 241whp at 11.6A/F for safety and clutch life. The car started to slip clutch atfter 5k rpms so I didn't try to push more boost to get more power. Last night I went to the track to get a baseline with stock clutch and the car made 14.24 at 101mph with 2.38 60ft with the clutch slipping top third and fourth gear. After that I tried to better the times but the clutch was slipping maddly in 4th and droped 3mph and times where 14.4 98mph. I am happy with the results bc's I know that with notting more than performance clutch and good tires the car would hit 13.8-7 with 103-4mph at 8psi.
Whould post the slips and dyno when scanned.. Other note RickyPR with his N/A RA hit 14.7 92mph drag radials Injen, custom downpipe and some weight redux..
Old Jun 15, 2005 | 08:27 AM
PGDlancer's Avatar
keep us posted, but why didn't you install a stronger clutch when the turbo was put in?
Old Jun 15, 2005 | 08:52 AM
Daddymac's Avatar
Me thinks I should go on a vacation to PR. They seem to REALLY be on top of the Ralliart Tuning down there.
Look at how many tuners and custom fab guys they have down there compared to pretty well ONE vendor here....RRM.
Old Jun 15, 2005 | 09:11 AM
I thought that i was going to handle 8psi. The car pulls hard to redline while the stocker drops at 6,000rpms max power was at 6.4krpms. Probably with 12psi and clutch safely 275-285whp maybe more.
Old Jun 15, 2005 | 09:38 AM
blk-majik's Avatar
did you just use the standard rrm piggyback for air/fuel, or did u get ahold of their turbo unit to handle timing?
Old Jun 15, 2005 | 10:53 AM
I use the standard RRM piggy with the R4 software but its a pain in the a$$ to calibrate with big injectors. Would have used a PSC1 for boost aplication adjusting or enrichment by boost. Got a great deal on the Piggy.
Old Jun 15, 2005 | 11:23 AM
blk-majik's Avatar
psc1-006 (karman -> maf) for our car? did you have to manually modify ignition as well? or did it take care of itself?
Old Jun 15, 2005 | 11:49 AM
PR_Mivec's Avatar
i saw that car on monday and it runs quite good....
i was the one w/ the silver ra running aginst the corrolla's and eclipses
Old Jun 16, 2005 | 04:40 AM
PR Mivec, the one that ran on monday wasn't me. I ran tuesday night from what I'm told both cars look almost the same. The one that ran monday has microtech and deleted trottle by wire. I will have to put some sticker or change wheels to make it different and people dont get confused. Anyways hope to se you soon at the track.. RA representing.
Old Jun 16, 2005 | 10:27 AM
reimundo's Avatar
this is what i want to know too
Old Jun 16, 2005 | 07:16 PM
Red Dragon's Avatar
cant we get parts from there?
Old Jun 26, 2005 | 07:21 PM
PR_Mivec's Avatar
you can ask us what you want.. but 99.99% of the time you guys find the parts for a better price.....
Old Jun 26, 2005 | 07:48 PM
Ralliart403's Avatar
750 Injectors??? I would like to know where you got every part for your car... You mentioned bigger injectors but fuel pump??? fuel rail?? where did you get your manifold? I have SOOO MANY QUESTIONS! but i know it will get lost with crap like....(you said your gonna change your wheels ! WOW to what !) because every GOOD post always gets lagged with crap!
Old Jun 27, 2005 | 11:35 AM
rickyMivec's Avatar
P.R tuners the best and my times got better 14.5 93 N/A.
253 whp for $2200 thunder rush
Old Jun 27, 2005 | 12:00 PM
PR_Mivec's Avatar
^^ dammm!
