Turbo Timer for Ralliart
I just ended up getting an alarm system with a turbo timer built into it. It works pretty good. 1, 3, and 6 minute cool times. No problems so far. Just some wiring to the ignition harness required.
Originally Posted by wide open boy
now im not new with turbos but im old school these new things dont make much sence to me im use to the jsut leave your car running for 5 minutes befor you turn it off what dos a turbo timmer do
Well to answer this question YES the Lancer Ralliart and Evolution share the exact same ignition harness, i have just installed a HKS Turbo Timer in my ralliart and my harness and Timer were out of an Evo in Japan, so no problem there.
Not wanting to sound too stupid but why do you want to have a turbo timer in your car...
These days the modern turbo has a oil line going to the turbo... so there should be no seizing up and it should not be running flat out anyway by the time you have stopped the car
I am yet to see a EVO or any other new or modern turbo car come from the factory with one installed...
I personally would not bother with one but if it's looks that you are after then by all means get one
yitzac1990
Lancer Engine Management / Tuning Forums
Feb 23, 2009 10:19 AM
