turbo help
turbo help
hey,
currently doing a turbo build for my RA, and bought a t3/t4 turbo
but i think something is weird
i think the turbo is "backwards"
if u see in the pic below it shows the flange that hooks up to the manifold which is normal, but on that same side its the oil drain said?
coz its bigger than the other which is the oil feed
so how i initially planned to mount it goes out the window coz dont i need the oil feed hole on top and drain on the bottom,
so what i need to know is how hard would it be to rotate it around how i want it
can i just undo the bolts on the side and rotate it, or should i take it to a shop and see if they can do it?
also, on the turbo there is a hole, usually where a wastegate door should be(where my finger is in), but there isnt one on there and doesnt have an actuator so im going external WG, so what do i do with the hole, just weld it up?
thanks
-Steven
thanks
-Steven
ok did it, was a really hard to undo those bolts, but got it done and rotated it to hopefully how i want/ need it .
here is a pic of the final result:
just want to say thanks for the help guys even if the question was a bit noobish, but just wanted a lil help before i broke somehting
and for appreciation im adding just a couple of pics from when i washed my car the other day:
im pretty confident it is a hole for an internal wastegate as it is on the part where u would connect the dp but before the wheel
ie this flange would fit it: http://cgi.ebay.com.au/STEEL-T3-T4-T...QQcmdZViewItem
but since im gonna go external wg, i think ill get this flange and just cover up the hole: http://cgi.ebay.com.au/STEEL-T3-T4-T...QQcmdZViewItem
hopefully that is better than welding, so if im not ment to it can be reversed
Yeah that hole is there for the internal wastegate, if you had one and the flange that goes there, you would have a little trap door inside that housing wich covers the hole until the boost pressure is reached then would open to let the eahxuat pass by....but if you are going with and external wastegate then you need to block that hole up
On a side note good luck with the project, nice to see more lancer's going turbo
ty all for help
i know im going to be a pita coz i like to get confirmation on things even if i have read it 100 times here, lol, just paranioa(sp?)
i also have to try to pace myself, coz i wanna get it done asap but i know its gonna take me a while to get everything i need
