04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
what a mess
Old Dec 12, 2007 | 08:54 PM
edovio's Avatar
what a mess
i just removed the fuel pump in search of a potential problem as to my bogging situation and after putting it back in it wont start, i took it out again to make sure i put it back ok and now it wont start. man o man i am very frustrated with all this. all i ever wanted was to be boostin ahha now it seems im ripping everything apart in search of god knows what. my injectors are all working, i ordered new plugs and will try them out when they get it. hopefully i can get some fuel runnin again. mad respect to all moders out there . Patience is a must. although im wearing thin.
Old Dec 12, 2007 | 08:57 PM
Cow town racer's Avatar
Ya, I don't know if anyone put this thought out there, but maybe the tune just isn't running sufficiently for your car. If you have a wideband you would be able to tell what it is pretty quick.
Old Dec 12, 2007 | 10:33 PM
BlueSteel-06's Avatar
Are you sure you put the fuel pump back in right. There is a fuel pump pressure regulator on the side of the fuel pump that might have fell out. When I first installed my turbo I didn't get the fuel pump installed correctly and the next day I couldn't start the car. Checked the fuel pump, it looked fine, after about 30 minutes or so of scratching my head, I looked in the gas tank and saw the fuel pump pressure regulator sitting at the bottom. fished it out, re-installed it and ensured a tighter fit on the fuel pump assembly and the car started right away.
Old Dec 12, 2007 | 10:34 PM
I keep telling you this but take it to AFI to have your tune looked at ASAP.
Old Dec 12, 2007 | 10:47 PM
Ya, I agree with you on that, because to me it sounds like he is leaning out in the upper range.
Old Dec 13, 2007 | 08:14 PM
edovio's Avatar
thanks again guys,,,i plan on going first thing in january,,unfortunately i have to go to mexico for xmas,,,im too busy for all this stuff. but i cant wait to get her goin again, thats probly the fault with my fuel pump too, thanks again guys
Old Dec 13, 2007 | 09:31 PM
Here you go;
FUEL PUMP MODULE DISASSEMBLY AND ASSEMBLY
DISASSEMBLY STEPS
1.CAP
►A◄2.O-RING
3.PUMP HARNESS
4.FUEL PUMP BRACKET
5.FUEL PUMP CUSHION
6.FUEL PUMP
►A◄7.GROMMET
8.FUEL PUMP PRESSURE REGULATOR
►A◄9.O-RING
10.FUEL TANK PUMP HOUSING
Look at #8, once you have the fuel pump assembly out, its pretty esay to see. Just make sure that in place when you put bottom bracket back on.
